Cam upgrade
Old 08-16-2020 | 10:09 PM
professorlarr's Avatar
professorlarr
6th Gear
Default Cam upgrade
03 Electra Glide Classic FLHTC,any ideas on cam size upgrades,S&S 509
Old 08-16-2020 | 11:10 PM
matt_eglide's Avatar
matt_eglide
What type of riding do you do and where, where are your current shift points (rpm), so you ride more solo or 2-up, what’s your budget, are you doing the work or farming out to a shop? Too many questions based on your initial post to suggest anything other than ride what you have and then make a guess later...
Old 08-17-2020 | 04:54 AM
eighteight's Avatar
eighteight
509 is a good cam only upgrade for the 88”
professorlarr (08-17-2020)
Old 08-17-2020 | 11:12 AM
predatornut's Avatar
predatornut
It looks like you answered your own question.
Old 08-17-2020 | 11:44 AM
470004's Avatar
470004
You will get a lot of different opinions.
Old 08-17-2020 | 12:34 PM
LazySundays's Avatar
LazySundays
Basically the same bike. Love my 509c. Bike pulls hills better 2 up and no longer feels like it's out of steam at 70 mph
Old 08-17-2020 | 12:44 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
I have had 509G's in my 03 bagger for 8K miles, with a Thundermax tuner and O2 sensors
Once it goes above 2500 RPM's it scoots right along, great for highway and passing as it really comes alive at over 2800 to 5000,
It is a good broad power band cam for the TC88, where I am told the 510 is a tad peaky and only likes high rev's
and you are not going to have to worry about coil bind in the heads.
I
Old 08-17-2020 | 05:21 PM
hattitude's Avatar
hattitude
Certainly not knocking the S&S 509 cams... I know nothing about them....
Just for variety sake, my go to cam for an OEM 88' has always been an Andrews 21 cam..... They come on about 1700 rpms and go strong up to about 5K rpms... good bolt-in, mid range cam... where most people ride...
Old 08-17-2020 | 05:56 PM
eighteight's Avatar
eighteight
Good advice from an author of many intelligent posts
Superdog3:16 (08-17-2020)
Old 08-17-2020 | 06:29 PM
eighteight's Avatar
eighteight
I[/QUOTE]
Installed 510gs in 02 to eliminate early TC chain/ bearing issues. as that was the “bolt in” back then ( 509s not yet invented/ offered)
Worked well for me on , light bike , light rider
( relatively speaking)
Replaced with 570 g with 98” build and added compression, heads, yada, yada
EDIT
good advice in post number 2
again, goals and budget
