07 runs rich
Old 07-26-2007 | 01:38 PM
jim hicks's Avatar
jim hicks
Stage IV
Default 07 runs rich
I have an '07 Ultra. Just hada stage one completed and it backfires against compression. The right tail pipe has more soot, and I assume that means the front cylinder is running rich. Was this not mapped right, or is there another problem?
Old 07-26-2007 | 01:45 PM
Zimbob's Avatar
Zimbob
Default RE: 07 runs rich
Sounds like another problem. Have the dealer take it back and fix it right.
Old 07-26-2007 | 01:53 PM
Chicago Spike's Avatar
Chicago Spike
If you have the stock pipes, the right pipe will always have more color because of the crossover pipe that connects the rear cylinder pipe to the front cylinder pipe. The exhaust gasses will take the shortest path out which would be the right side.
Old 07-26-2007 | 01:54 PM
nvsteve's Avatar
nvsteve
Your right pipe gets all the exhaust from the front cyl. and most of the left cyl., so the soot could be from both or either.
Take it back. No way should the download make your bike run rich.
If anything it will still be too lean.
Old 07-26-2007 | 03:00 PM
alexcue's Avatar
alexcue
nvsteve, hit it on the head. the normal stage 1 download will not make your bike run rich. It still has to comply with EPA, which = lean! Something else is wrong, maybe an intake/exhaust leak or something. Have them fix it.
jake.h
07-01-2016 10:12 PM
kingnothing71us
07-06-2015 09:56 PM
foxtrapper
09-23-2013 09:47 PM
bigorange
02-18-2008 02:47 AM
serverpimp
Exhaust System Topics
05-19-2007 08:23 AM
Quick Reply: 07 runs rich
