Super Trapp Slip om baffles
RE: Super Trapp Slip om baffles
ORIGINAL: itsmyforte
ultra classic
since you have had yours out so many times. can you tell me if the pipes are made identical? i read a small except in the american bagger mag pipe shootout that one of the pipes weighed 1 lbs. more than the other.
ultra classic
I called Supertrapp yesterday and they said the Screamn' Eagle Touring Performance mufflers & the Supertrapp S E's were pretty much identical andthe bafflesare the same. The sound could probably very depending on the size of your engine, number of miles on your mufflers and weather your running true duals.
I have billeted tips on mine, but would like to know if changing the tips to something like a set of turn downs might help; anyone try out there try a different tip to see?
ORIGINAL: cobrabob
I think you are right about not being able to changle the baffles and I don't think that is really the problem the more I listen anyway. I am going to go to a true dual setup so the majority of the exhaust is not coming out of the right pipe. I can barely hear the left pipe when I am going down the road but the right one gets annoying. I think when they are balanced out, they will sound fine.
Smitty
Just got the new Supertrapp baffles today. The baffles include a small cup/sleave looking metal piece, any ideas where that piece goes? The small piece is loose and not attached to any one part of the baffle.
This is what Supertrapp said " The baffles are also used for earlier model pipes with a smaller inlet, just discard the adaptors."
Just replaced the baflles, it took about ten minutes to do both. They came out easy and went in easy. I did have to very lightly tap the baffle with a deadblow hammer to line up the bolt holes.
I started the bike for a brief minute (930pm) and it almost sounded the same, nice deep rumble. The test is going to be at cruise, thats where the jackhammer noise drove me crazy. I'll post again as soon as I get to ride the bike.
Finally got out with the new Supertrapp baffles. The new baffles are quieter than the Mikuni baffles. No surprise there since the right side Mikuni baffle is half the size of the Supertrapp baffles. The experiment worked! I can cruise again without getting a headache and ringing ears.
Iddle, the mikunis are louder and have adeeper tone. The Supertrapp sound great, but not as nice as the Mikuni.
No issues with my SERT tune. The bike runs as before. There is less popping with the new baffles.
The mikuni baffles sound louder/better while accelelrating. The Supertrapp sound great as well, not as loud.
Cruise, the Supertrapp sound glorious. No jackhammer sound. The wind is my enemy again, I wear a full helmet-always. At 60+ is where the Mikuni bafles failed and made the ride horrible. So it appears that the new baffles are a good compromise with sound/noise. A good investment if you don't want to replace the mufflers. You are going to pay about $155 including shipping for the new baffles.
I believe that you can just purchase one baffle ($70) and just replace the right baffle and most likely get the same results.
