Gauges
Gauges
I've been busy breaking in the new Street Glide and had a couple questions about the gauges.
What does the "Air" gauge do? If it is supposed to give the temperature it is about 30 degrees off.
Also, what should the oil gauge read out to? When I'm idling it is almost 0. When I'm riding it stays about in the middle at 32.
Thanks,
Barry
Thanks,
Barry
RE: Gauges
The air guage does nothing....other than tell you what outside temperature is. Completely useless and it is seldom accurate. Replace with oil temperature guage instead.
The oil pressure guage is normal and is acceptable. 32 is perfectly normal and at hot idle.....it can be around 5. If it drops to 0 and your oil pressure light comes on......then stop. Until then, all is normal.
