Oil Filters
Old 07-24-2007, 12:55 PM
Yambo's Avatar
Yambo
Yambo is offline
Default Oil Filters
Lotsto read about which oil to use nothing about which oil filter to use.Is one name brand oil filter better than others?. If so, why?.
Old 07-24-2007, 01:06 PM
Peppa1's Avatar
Peppa1
Peppa1 is offline
Default RE: Oil Filters
I'm thinking why not just use the same kind that comes on the bike .... purchase from local dealer... qwik & easy.... no fuss - no muss !!!
flht69's Avatar
flht69
flht69 is offline
ORIGINAL: Yambo
Yes, Go with Harley brand. I used a off the wall filter last year and ended up with oil over the place. The filter just wouldn't seal right. Harleys filter works every time.
Old 07-24-2007, 01:09 PM
petemac's Avatar
petemac
petemac is offline
Use HD filters and buy them a few at a time off the web from someone like Zanotti's. Or just buy them as you need them at the dealer. Don't forget the O ring.
Old 07-24-2007, 01:21 PM
Lost1's Avatar
Lost1
Lost1 is offline
Black H-D filter here, 8 bucks from my dealer.
Old 07-24-2007, 02:13 PM
twin88cam's Avatar
twin88cam
twin88cam is offline
K&N. # kn171-c. Alot easier to remove with the built-in nut on the end
Old 07-24-2007, 02:37 PM
madmikee's Avatar
madmikee
madmikee is offline
As I understand it, the HD filter does the job down to 5 microns, and the K&N is only down to 10 microns.
I'm not aware of any filter that does the same job as the HD filter, BUT I am not very well educated in this area either
Old 07-24-2007, 02:43 PM
gordon188's Avatar
gordon188
gordon188 is offline
I have used harley filters for years, I do want to try a K&N, seems better with the nut.
Old 07-24-2007, 02:55 PM
fastony's Avatar
fastony
fastony is offline
http://motorcycleinfo.calsci.com/Filters.htmlThis might help, I have an old S3 Buell (Sportster motor) that turns a lot of RPM's and I have used Fram from new... [:-]
Old 07-24-2007, 04:54 PM
Professor's Avatar
Professor
Professor is offline
I run Mobil1 and Purolator. Bought Mobil 1 at Autozone--great reviews on this filter. Purolators (more surface area inside to collect debris) I bought from AMAZON--about $5 each. Bought several and saved the freight. Both are black. I don't like the chrome--just more stuff to polish plus I heard that the black run about 10 degrees cooler than chrome.
Quick Reply: Oil Filters
