Well Nuts
Well Nuts
I put one in and all it does is spin. Is there a trick of the trade to get these to sit in it's place? My narcelle has 8 holes...service guy said my bike has 7,he's wrong. Looks like p/n 5210 has been replaced.....
https://www.jpcycles.com/product/972...E&gclsrc=aw.ds
Try screwing the screw in without putting the rubber part in the well hole as stated above to make sure the screw goes into the nut. Then put a few washers between the screw and the flange of the well nut and tighten the screw so the nut pulls into the rubber part and expands the well-nut some. Then install it into the hole and it should be a press fit. so it holds the rubber part while you are tightening the screw.
Had the same issue with my Honda VFR Fairing well nuts as some of the holes in the ABS fairing were a little larger. Another trick is wrap some electrical tape around the well nut to make it a tight fit in the hole so it does not turn.
Good morning!
When I replaced my stock headlight with LED on my '20 RK there was one of these inserts spinning. It pulled out of the nacelle when I removed the ring.
It appeared to me that these were supposed to act like a rivet when first installed. So I re-inserted and held the back half with pliers while I tightened the screw. That worked for me. The insert is meow tight like the other 7.
Would you try this?
Doc
nobodyknowsme (06-16-2020)
