08 EG Has True Duals, Switch To 1 into 2?
Old 06-03-2020 | 09:42 PM
eli_harper13's Avatar
eli_harper13
6th Gear
Originally Posted by Andrewwayne
I changed my from true duals to a 2 into 1 and I’m ver happy with the change. I used the Rinehart 2 into 1. My bike has a 96in too. It improved the low end and I really like the sound. Do cams too while the exhaust is off that will make the most difference.
I do really like the sound of Rinehart’s, which is one reason why I lean towards not making a chang. Which cams did you go with?
Old 06-03-2020 | 09:55 PM
Ben221's Avatar
Ben221
I think a switch from a true dual to a 2/1 is about the largest swing in performance you can get. I went from decat’d and debaffled stock exhaust to a Pro Pipe and my FP3 showed significant HP and torque gains. Plus it sounds so good.
Old 06-03-2020 | 10:58 PM
eli_harper13
6th Gear
Really? It seems, from my reading, most people say that you probably won’t notice a difference between the two. But I do see a few people that have had both and claim it’s a big difference.
Old 06-04-2020 | 07:46 AM
Andrewwayne's Avatar
Andrewwayne
I went with Andrews 48 and used a powervison tuner. I like the Rineharts sound that’s why I went with there system. And the price is not bad either. In my opinion after installing it, a 2 into 1 looks cleaner you don’t have a pipe running under the bike or down the other side
Old 06-04-2020 | 05:43 PM
peterllo's Avatar
peterllo
Default True duals
I have an '07 RK. V&H Big Shots, stage 1 w/SEPro tuner. The bike pulled and ran strong when I got it. It would pop on decel. The head pipe cracked so I went with V&H true duals keeping my pipes. No pop following that. Still sounds great, might have a little less torque but I'm not a hot dog and it pulls just fine off the line and on the highway.
Old 06-04-2020 | 06:16 PM
Ben221's Avatar
Ben221
I noticed low end torque and better sound Immediately. My FP3 has a Torque and HP reading. I am not sure how accurate but it was a substantial increase. There are dyno tests on true duals and 2/1 showing improvements so you can get your proof.
Old 06-05-2020 | 09:55 AM
Zedbra's Avatar
Zedbra
I've put a lot of work into my 08 with a 110" TC and though I had the idea and funds for new exhaust, I kept my Rinehart true duals. I like having the heat split so that my right leg isn't burning, and I like the looks of them. With the right cams and tune, I don't feel like I am missing anything on the low end that a new exhaust will offer. With the 585G cams, my Road Glide can get the wheel in the air in both 1st and 2nd gear, not sure how much more torque I need on a 950lbs touring bike.
touchdown (06-05-2020)
Old 06-05-2020 | 12:48 PM
Ben221's Avatar
Ben221
Good points. You can get torque with a cam, more CI, exhaust or other tuning I guess or all the above. My 103 TC was torque starved after my exhaust and intake mods. My FP3 and Pro Pipe gave me some back. I may do a torque cam at some point but I am happy with its ability to pull my wife and I loaded down.
Cheers.
Old 06-05-2020 | 05:40 PM
eli_harper13
6th Gear
Cheers.
Anybody know about the cost of getting some cams? Maybe the SE-255 cams.
Old 06-05-2020 | 05:44 PM
CGLTD's Avatar
CGLTD
I did an internet search. It says the cams are 349.95 from HD.
Quick Reply: 08 EG Has True Duals, Switch To 1 into 2?
