Advanblack mid-frame air deflectors
Old 08-06-2020 | 10:22 AM
JimL_15 Electra Glide's Avatar
After you fight to remove the top bolt to install the right side notch the top hole and install bolt and washer just snug to install loosen it enough to slide fairing in and tighten.I discovered this gem when I did my rocker lockers and zero room. This was my fix to the problem. Use the factory bolts as the junk hardware they send is laughable. Use factory hardware.
Old 08-06-2020 | 01:30 PM
maxxym's Avatar
maxxym
Funny. I just installed set from Hogworkz. Their instructions were written by a 5 year old. Same as you, I thought the bolts were too long, but I just kept turning it and finally they went all the way. Quality is pretty good too.
Bushy
06-16-2018 12:36 PM
goodluck
General Topics/Tech Tips
01-20-2015 06:31 PM
indianaironhead
Ironhead
21
01-03-2011 08:51 PM
dogster
EVO
08-27-2010 09:46 AM
PetersHog
08-31-2009 12:16 AM
Quick Reply: Advanblack mid-frame air deflectors
