04 RK won't turn over after cam shoe and new cams
So i finished my cams and got everything back together. I put in s&s 509 cams and new cyco tensioner shoes. So I got it all back together syarted it up and it died after about a minute. It sounded good for a but then died. Now it won't turn over and the headlight is very dim. I also changed to adjsutable pushrods, changed the oil and filter, unplugged battery, and have the battery tender on it now. Followed directions very well but something is wrong. I am curious if changing the oil was a bad idea and should've left it alone for a bit. Also the bike will turn over then start to click like a dead battery. Anyway I'm at a loss. Any help please. Thanks as always to all!!!!
My guess is its the battery.... but why would ti die now???
Because everything works until it doesn't anymore. Sometimes a failure is a clean, stand alone failure, sometimes it is coincidental with something else. How long did the battery sit without a tender while the work was being done? Charge it and get it load tested.
Did you check trouble codes? Might be a good place to start.
After I did my Cams the first thing I forgot was to put the spark plug wires back on. Caught that and still wouldn’t start. Then I noticed the ECM plug dangling... Anyway mine was an easy fix and was fine after I plugged everything in. It did die once before it started acting right.
Hopefully it ends up being an easy troubleshoot...
So you say it started and died. Then it won't turn over. Then it will turn over then it won't and clicks?
So what's the battery voltage read? How old is the battery? What's the voltage read when the starter is engaged? Have you double checked your cam and pushrod install as in cam timing and pushrod adjustment? What's your CCP with those cams?
