What is best replacemet bulb for 07 lights?
RE: What is best replacemet bulb for 07 lights?
ORIGINAL: lilarlen
If you are taking about your running lamps… well that is a different write-up depending on bike model and year.
For you with a 07 you have 27.5 watt bulbs (881 bulbs: Base PGJ12 - Right Angle) in your running lamps. You can install 37.5 watt (894 bulbs: Base PGJ12 - Right Angle) on each side for more lighting.
Little Arlen
Little Arlen
SILVERSTAR They make origional equipment bulbs look like candlelight. Here's a site that will sell them in a single bulb pack. Most automotive parts dealers only have them in packs of two. http://autoaccessories-4-less.stores...net/index.html
I too use the silverstar from Sylvania for the primary headlamp, much much brighter than the stock, for the passing lights I use the heliolite 881 32w xenon white high wattage, they work great, only 5 watts above the stock bulb and many times the brightness...... they cost 25.95 for a pair where I bought them, just pulled up the reciept...... got them from a company called Eautoworks Inc. in the Los Angeles area, if I remember right they shipped same day and I received the next day.... also bought the led tail lamp bulb with 27 led's in it ..... bought the load resistor too didn't end up needing the resistor so still in my garage... the led tail lamp was 17.95....
eautoworks.com
led tail lamp sku-106942
Passing lamps sku-38116
Load Resistor sku-33226
eautoworks.com
ORIGINAL: Macadoo
What bulb is the brightest yet will not cause any over heating?
Kuryakyn sells these for about $9.
ORIGINAL: Monstermile
Stick with the stock light and add some kind of auxiliary lighting. Those aftermarket "brighter" bulbs are junk and will not last.
