KST Mayhem Bagger bars
Old 05-07-2020 | 11:59 AM
Justin Barringer's Avatar
Justin Barringer
Default KST Mayhem Bagger bars
Hello all! I have a question for those who have or are running KST mayhem bagger bars on 14 and later Street Glide. Have you run into any issues using the stock clutch and brake lines? Reason I ask is I took my bike up to the local Harley dealer and showed them my proud install. They said that in 6-8 months there will be a failure on those lines do to the rerouting of the lines in the neck? Thanks for your answers.
Old 05-07-2020 | 02:38 PM
Lude-a-tick's Avatar
Lude-a-tick
What height bars?
Old 05-07-2020 | 02:40 PM
Redbeard719's Avatar
Redbeard719
Veteran: Marine Corp
LOL, if that's the case, there have been and will be a ton more that fail before yours due to the same reason.
I haven't seen a single case of the hydraulic lines failing, and I'm on the forum almost daily. I think you'll be ok.
Old 05-07-2020 | 03:08 PM
dusturbd's Avatar
dusturbd
I have there 12” with stock lines and 0 issues
Old 05-07-2020 | 03:41 PM
Daddy454's Avatar
Daddy454
I've had my 12s on for 3 years and no issues.Much ado about nothing.
Old 05-07-2020 | 05:54 PM
Justin Barringer
Originally Posted by Lude-a-tick
What height bars?
12” bars
Old 05-07-2020 | 06:18 PM
Lude-a-tick
As long as your routing is without pinch points and doesn’t interfere or impede turning, you’re good to go.
Old 05-07-2020 | 08:56 PM
boasty's Avatar
boasty
Find a new dealer
The following 3 users liked this post by boasty:
BelchFire (05-08-2020), Carolina Dreamin' (05-08-2020), OkieBill (05-07-2020)
Old 05-07-2020 | 09:26 PM
TXCHOP's Avatar
TXCHOP
Depends if you take the extra few minutes and run the lines properly. But never usually an issue.
Old 05-08-2020 | 06:18 AM
BelchFire's Avatar
BelchFire
KST says Rushmores up to 12" can be done with stock cables and lines, but needs wire extensions. Sounds like you're shop is butt-hurt over not getting to do the install.
The following 3 users liked this post by BelchFire:
07FXSTOki (05-08-2020), Buster (05-08-2020), Carolina Dreamin' (05-08-2020)
HD32141
11-04-2018 10:46 AM
Hilowaiian
04-19-2017 10:07 PM
CanuckWhiskey14
02-01-2015 12:17 PM
Lo 1
2014-2023 Touring Models
07-21-2014 08:57 PM
beeker356
08-01-2012 04:45 AM
Quick Reply: KST Mayhem Bagger bars
