New to Harley, getting 2020 RGL -- What should I know?
Probably the number 1 thing I wish I knew when I got my 2002 Road King was that if you come to a stop with the front brake and the front wheel turned, it's going down due to weight transfer. So when coming to a stop, use the rear brake or have the the front wheel straight. Maybe fixed for 2020 or earlier, maybe not, I don't know. Enjoy and welcome to the forum.
Less dive in the forks or a slower dive in the forks would be a good start. Maybe not physics, but some Engineering and Testing to validate would be a start. I've had 5 other bikes and none of them ever did that crap, but 80% were foreign made and half the weight or less.
This is NO FUN what so ever, read and LEARN the security section of the owner's manual, set a PIN and learn how to use it. Otherwise you will be sending in a request for help getting your bike started when you are stuck in the middle of nowhere (if you are lucky enough to have phone signal there. (Provided the bike has a factory security system.)
The following 3 users liked this post by btsom:
The following 2 users liked this post by Redlegvzv:
GoofySB (05-05-2020),
johnanderson (05-08-2020)
The following 2 users liked this post by Dan89FLSTC:
DanHappy (05-05-2020),
If you change the PIN, write it down before you change it, that way you won`t forget it right after you enter it, (like forgetting a persons name, right after you meet them for the first time ).
