Rear air shocks oil
Old 05-03-2020 | 11:57 AM
Mike Bullis's Avatar
Mike Bullis
Stage I
Default Rear air shocks oil
Rear air shock oil I recently bought a used set of 12 inch air shocks to lower my bike a little. I did not realize they had oil in them. That being said draining the oil was very simple turn them upside down it all ran out. My problem is when I try to put oil in it just pushes it right back out how do I put the oil in I've tried everything thanks
Old 05-03-2020 | 01:57 PM
sabunimwil@gmail.com's Avatar
This should help
SFinley70 (05-03-2020)
Old 05-03-2020 | 04:13 PM
caulk04's Avatar
caulk04
I redid mine with, I'm almost positive, 7.5wt shock oil. A little firmer than stock, helps slow down the compression and stop bottoming. If you're heavy that is.
Old 05-03-2020 | 04:38 PM
Cozz's Avatar
Cozz
I just did mine with a mighty vac, harbor freight version. You’ll need a barb fitting to use in place of the airline fitting. 5/16 thread, I think, barb on the other end. I got one at autozone, 4 bucks. Put the shock in a vice right side up, pull a vacuum on the shock. It sucks the oil right in. I don’t know how else you could do it. The hole is very small to re- fill through. It worked just fine for me.
you can also empty out the old oil with the mighty vac.
Cozz
04-08-2020 01:42 PM
DavidStiebel
09-20-2014 12:36 PM
heavymetalthunder
05-11-2012 08:03 PM
Mike67
05-31-2011 10:47 AM
terrysillik
05-29-2011 08:55 PM
Quick Reply: Rear air shocks oil
