Detachable tour pak mount: will not latch into place
Old 05-03-2020 | 04:32 PM
tonyd2017's Avatar
tonyd2017
Default good advise
Originally Posted by Senecagreen
The rubber part the latches latch on to are not round. They are eccentric. Loosen the bolt that holds them on where you can rotate the rubber docking part and rotate it a quarter turn and try the latch again. If it still does not latch rotate it some more until the latch latches.
They are eccentric so you can take the slop out so the tour pack doesnt have play in the mount once latched. Each side will have to be adjusted and if you have something else you attach when not using the tour pack it may have to be adjusted for that. I ran into the same problem. This is true if you are using factory docking points. Aftermarket I dont know.
i do the same thing, i do leave the bolt slightly lose and latch up the tour pack then I tighten the bolt. easy as pie.
Old 05-03-2020 | 04:33 PM
RomeoTango's Avatar
RomeoTango
Originally Posted by unclerog
I read the instructions that came with mine ! Sorry to be a smart *** but,,,,,,,,,,
No worries. Though, of the instructions the only mention to my problem was to "check rack alignment." A bit ambiguous, but good advice to always check the instructions.
  1. See Figure 1. Place the front Tour-Pak rack notches, with bushings in place) onto the front docking points (B). Make sure the notch bushings (4) seat fully into the front docking points.
  2. Position the detachable latches (6) over the rear docking points (C). Verify that the rack (1) sides and latches locate into rear docking points.
  3. Push down the rear of the rack. Push the latch lever forward until it clicks into place. If the latch does not close easily, do not force. Check the rack alignment.
  4. Connect all Tour-Pak harnesses and wiring.
bigheadted
02-21-2014 08:51 PM
captainron62
10-11-2013 05:26 PM
bdjhog
11-16-2010 12:36 AM
Rhinohd
07-18-2006 12:59 PM
BirchwhiteHD
05-10-2006 06:35 AM
Quick Reply: Detachable tour pak mount: will not latch into place
