Can HK Radio Push 4 Ohm Speakers
Thinking of putting some Polk Audio Speakers on the 07 Ultra. They are Marine Grade, fully waterproof but 4 Ohm. I know the current speakers that come on the Ultra are 2 Ohm. J & M and Hog Tunes seem to be 2 Ohm as well.
Does anyone know if going to 4 Ohm all around will cause an issue?
RE: Can HK Radio Push 4 Ohm Speakers
bonzo2 ,,,,,,,
using 4 ohm speakers for the 2006-2008 HK audio system will not cause a problem at all, in fact the amplifiers will actually run a little bit cooler than with the 2 ohm speakers ,,,,,,
however, the amount of power the speaker will receive from the amps will be reduced because of the higher impedance rating, and this will cause a corosponding reduction in volume at the same setting on the radio, compared to a 2 ohm speaker of the same quality and design ,,,,,, however slight this reduction might be ,,,,,,
certainly I am biased, but I think you will find the J&M speakers designed specifically for this application on your Harley will be just as water-resistant as the Polk marine speakersyou are conisdering and in addition, will give you the best sound available from the HK audio system on your Harley ,,,,,
JMJOHN ,,, john@jmcorp.com ,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
ORIGINAL: Jakie
Not to be jumping in on your ?? but I have a 2002 Electra-Glide Standard with no radio in it.
I was told that the speakers are in it and all I have to do is
put a stereo in it. What are most people recommending?
