New Guy - !4in bar install issues
Old 04-18-2020 | 01:24 PM
Roadglidespecial2019's Avatar
3rd Gear
Angry New Guy - !4in bar install issues
Hello HD Community,
Looking for some help here, i decided to install my 14inch Paul Yaffe bars. I have a 2019 Road Glide special, I watched and read about 50 videos before attacking this. I kept stock wires it was snug but it fit. After a few hours we had everything done. After wiring it all back together none of the switches on my bars will work or my speedometer. Also noticed that the fuel and battery gauges on my fairing wont even turn on. The bike itself will get power like the main head unit and i hear the fuel pressurize. But other then that nothing i cant turn over the engine now. I checked all the wires and all the fuses under my seat everything looks good. All connections are good and the pins were checked also. After speaking to some technicians from rev Zilla they said i had to have snagged or crimped a wire while running them through my bars because of the hard 90 degree angles.. I found that hard to believe since the wrapping was so thick on the wires so i did everything to avoid pulling them out to make sure this was not the case. After being stumped for hours i said screw it and pulled all the wires back out to make sure that was not the case. After pulling all the wires out they were completely fine. If anyone can shed some insight on what i may have missed please let me know I’m dying over here lol. Thanks.
Old 04-18-2020 | 02:27 PM
Hammz's Avatar
Hammz
Did you pull the 50A Main before starting?
Have you actually removed all the fuses & tested them with an ohmmeter?
Old 04-18-2020 | 02:53 PM
3rd Gear
no like an idiot i did not originally. Which i was told i could have blown one of the fuses in the fuse box, but i tested all of them and they were fine.
Old 04-18-2020 | 04:45 PM
TXCHOP's Avatar
TXCHOP
Key Remote near the bike? Take a video and upload here.
azgrumbles (04-18-2020)
Old 04-18-2020 | 05:13 PM
Redbeard719's Avatar
Redbeard719
Veteran: Marine Corp
Did you reconnect the speedometer/tachometer gauge wiring?
I noticed not doing so will cause the issues you’ve described.
Old 04-18-2020 | 07:46 PM
azgrumbles's Avatar
azgrumbles
I did this like 3 times on my 15 RGS with no issues. If I can do it anyone can. It’s gotta be something simple. I never removed the main fuse either. Maybe the pins didn’t go back in the correct order?
Old 04-18-2020 | 10:20 PM
3rd Gear
Thanks for all the input guys. Just finished putting her back together. Turns out i have the fuses another check and idk how but this time around the 5a battery fuse was blown. Switched it out and boom power to the speedo. Thanks again.
Before the 14inch Paul yaffes
After 14in bar install
After 14inch install
The following 2 users liked this post by Roadglidespecial2019:
07FXSTOki (04-19-2020), azgrumbles (04-18-2020)
Old 04-19-2020 | 12:22 AM
Grouser62's Avatar
Grouser62
Glad it worked out and thanks for letting the forum know. Great looking install, enjoy.
Old 04-19-2020 | 12:33 PM
3rd Gear
Default Bars installed now check engine lights
So guys i spoke to soon. Now that my bars are on and everything is working i have a check engine light on. Checked for codes and literally everything is flashing yes for codes idk what could have triggered this. Ecm yes bcm yes speedo yes radio yes it’s all yes about 60 codes in all. Unplugged and plugged sensors in fuses all checked check all plugs under battery not sure what i do here. Thanks in advance.
Old 04-19-2020 | 12:49 PM
Hammz's Avatar
Hammz
Probably set those codes when the issue was there. Clear the codes, ride the bike, see if any set again, If so, there's still a problem. If not, cool.
Quick Reply: New Guy - !4in bar install issues
