Question about Thundermax Auto Tuner
Old 04-18-2020 | 09:54 AM
fooschamp's Avatar
fooschamp
Default Question about Thundermax Auto Tuner
Hey there Harley friends!
So I read all these great things about Thundermax tuners and I was able to get a good deal on a slightly used tuner for my 2013 Street Glide. It's the correct model for my bike.
When it arrived, the 02 sensors that came with it are GIANT compared to my stock 02 sensors. Is there some adapter I need so they fit or do they require aftermarket headers? The Thundermax Website appears totally broken which is an added bonus.
Old 04-18-2020 | 10:19 AM
HD Bobber's Avatar
HD Bobber
There are 18mm (your stock small O2) to 12mm adapters you can buy and screw into your exhaust O2 ports, but if your pipe has 18mm then the only way is to cut and weld new bungs or get new pipe.
is your exhaust header stock? Usually exhaust manufacturers make the bungs the bigger size, so it works on a variety of models and then you simply screw on the reducer onto the O2 to make it work.
Old 04-18-2020 | 10:33 AM
HD Bobber's Avatar
HD Bobber
Double check your part numbers:
309-460 is for 2002-2007 touring
309-362 is for 2008-2013 touring
Old 04-18-2020 | 10:53 AM
multihdrdr's Avatar
multihdrdr
There shouldn't be any adapters to put a 18mm O2 in a 12mm Hole even if you can find them ... If there was or is, they couldn't work correctly anyway
fooschamp's Avatar
fooschamp
Old 04-18-2020 | 10:59 AM
multihdrdr's Avatar
multihdrdr
You won't be/ wouldn't have been able to plug in the ECM cable had it not been the correct TMax ... HD changed the connector in 2008
Old 04-18-2020 | 11:16 AM
HD Bobber's Avatar
HD Bobber
Originally Posted by fooschamp
309-362
Try calling Tmax and see if you can buy the smaller O2’s and plug them into the unit or remove your exhaust and have a shop weld 12mm bungs in place of the 18mm.
are you using stock headers? If so ditch those and time for an upgrade.
Old 04-18-2020 | 11:38 AM
multihdrdr's Avatar
multihdrdr
That would have the same answer to the question ... "Do they make a 12mm Wide Band O2 sensor?" ... and you're not going to like it
Old 04-18-2020 | 01:09 PM
fooschamp's Avatar
fooschamp
I found a nice set of Vance & Hines headers for an '09 FLHX. They have the correct size hole for the 18mm 02 sensors. I'm just wondering if they'll interfere with anything on my 2013 FLHX?
Thanks
Old 04-18-2020 | 01:21 PM
23Seven's Avatar
23Seven
Get the V&H Headers and enjoy better exhaust and your tuner.
Quick Reply: Question about Thundermax Auto Tuner
