2007 Ultra bearing replacement
Old 04-15-2020 | 11:57 AM
Our07Ultra's Avatar
Our07Ultra
Default 2007 Ultra bearing replacement
Getting front wheel powder coated and and figured good time to replace bearings as they have never been replaced. Any preferred brand/make of bearings or get the MOCO EOM from dealer?
Thanks in advance
Old 04-15-2020 | 11:31 PM
HD Bobber's Avatar
HD Bobber
Personally, I would stick with HD brand bearings.
Old 04-18-2020 | 07:44 AM
Geoff1200's Avatar
Geoff1200
I went with All *****, no problems...
Old 04-18-2020 | 07:59 AM
decencyxdefied's Avatar
decencyxdefied
I have all ***** as well. It's not like your going to notice a difference with either bearing. Get what you can get to facilitate your build and get back on the bike.
Old 04-18-2020 | 08:42 AM
AlCherry's Avatar
AlCherry
You can mail order the aftermarket or you can go with the factory bearings. If you get them from the dealer they can install them at a nominal fee while you wait. Just remind them of the year of your bike because there is a offset of the bearings for the 07.
Old 04-18-2020 | 09:00 AM
Zerk's Avatar
Zerk
I could tell you one that would last 200k, but its for an FLHR.
I decided to replace one that one had 80k on it last year. I was little nervous. It just seems a lot worse now a days. Though I talked to one guy, who claims he did his every other tire change. Maybe fronts. He had an old bike too.
I would be ciurous if somethign better than OEM. I got to think there is.
They also say to make sure and you tq wrench on the newer styles. Though my first tire, I pulled on that breaker bar, until a crapped my drawers.
Old 04-18-2020 | 09:47 AM
multihdrdr's Avatar
multihdrdr
For the 2000-07 bikes specifically ... (and at this current point in time) ... get the OE bearings (Original Equip)
Old 04-18-2020 | 10:48 AM
MotoJockey's Avatar
MotoJockey
And when a guy with bearings as his Sig Pic tells you which bearings to get............ get them!
Old 04-18-2020 | 10:53 AM
multihdrdr's Avatar
multihdrdr
... And I still need to update it with the newest 9252A ABS bearing ... (has a Gray outer seal, but still with an Orange inner)
Old 04-21-2020 | 08:43 AM
Our07Ultra's Avatar
Our07Ultra
Thank you for the info gentlemen. Very much appreciated!
Quick Reply: 2007 Ultra bearing replacement
