I have read previous threads about this but most of the info is on the 88 or 95 c.i. I know the se 211 is a top end cam. Since the 96" is stroked and already has good bottom endI would think the 211 would be fine. Iknow I am going with se because mydealer will still honor the warrany. I also don't think thatthe dealer will go more than 9.5:1 compression. Will this be enough compression? Thanks for your help.The bikeis an08 RG.
The 96 has good bottom end with the factory cams but if you replace them with a cam that makes its power and torque in the upper rpm range you'll lose that bottom end that you like so much. You need to find a happy medium somewhere.
I've got the SE 255 , and it pulls great from 3000 up , there aren't to many options to keep it under warranty. I was looking at a 251 and the delaer said it would void warranty.
