2011. Is the primary vented?
Should the primary be vented on my 2011 FLHX?
Recently had my primary off to change the belt and replaced the inner seal while I was in there. Now it's leaking and I don't think I screwed the seal on install but I do know it's possible.
So, when I drained the primary it glugged a lot and I don't remember it doing that before. If there's supposed to be a vent that I blocked somehow, maybe the seal is fine and pressure is just forcing it out.
Double lip seal is bi-directional can go in either way, the old metal single lip ones you had to watch and how those went in depended on running a wet or dry ( belt ) primary.
