primary oil ??
ultraglide12 (04-07-2020)
do a clutch adjustment. if you used specific primary oil, you shouldn't have a slipping problem. if the dealer used formula +, it is about the same viscosity as a 50wt motor oil.
if you do an adjustment, and still have a slipping problem, i would drain the s&s and try either formula +, or shell rotella t 15w-40. it is jaso rated for wet clutch use. but logically thinking, if your clutch was working fine before, and now it isn't, then either your clutch is out of adjustment, or the oil is not compatible.
ultraglide12 (04-08-2020)
