KISAN HEADLIGHT MODULATOR IS NUMBER ONE!!! PLUG AND PLAY.
RE: KISAN HEADLIGHT MODULATOR IS NUMBER ONE!!! PLUG AND PLAY.
Rode around with theKisan on all day - what a difference.
ItDEFINITELY gets attention - all kinds of people gave me looks today.
Finally they see me clearly. Lots of smiles from other bikers and lots of people staring and pointing too.
>>>>>>>>>>>>&g t;>>>>>>>>>>>> >>>
OK Tex - I get a little clicking interference thru thru radio when on high beam???
Audible but not to the point of being annoyed.
Any fix for that???
THANKS Dave H.
Any fix for that???
THANKS Dave H.
Hmmm....funny - don't have it on mine. Sounds lahk ya need an RF filter - go by Radio Shack an' see if they don't have one that'll plug an' play. Ya might wanna contact Kisan first, though - they may have somethin' they kin recommend. They're aces on customer service!
Question for guys running the kisan modulator:
If it is wired to the high beam, in order to run the modulator you put your lo/hi switch on hi, right?
If your lo/hi switch is on hi, your passing lights are out (unless you do some wiring harness surgury)?
Thanks.
Thanks.
Best add on for safety, run one on all my bikes. You should be able to set it up to modulate either on high or low beam.
Thr Kisan is probabl the best quality, there are others that worl well, use google for vendors. Well woth it!
