Belt. Laugh at my pain.
Old 03-28-2020 | 02:54 PM
caulk04's Avatar
caulk04
Default Belt. Laugh at my pain.
So I seem to have picked up a rock and ruined my belt. Bike has just shy of 30k and shows no other problems. I will be doing the job myself and learning along the way. What items should I be changing or inspecting while I'm in there?
Also, should I stick with the Harley belt or are there good aftermarket options?
Old 03-28-2020 | 03:33 PM
eighteight's Avatar
eighteight
[QUOTE
Also, should I stick with the Harley belt or are there good aftermarket options?[/QUOTE]
No laughing here, that job is an 8 hr plus *** pain
stock gates poly belt is recommended
DanHappy (03-28-2020)
Old 03-28-2020 | 03:55 PM
btsom's Avatar
btsom
Just curious if the belt guard remained installed or had it been removed at some time in the past? Surprised to see damage on the outside side of the belt, did you find the stone, and if so, where was it lodged?
eighteight (03-28-2020)
Old 03-28-2020 | 03:58 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Pretty sure that wasn't caused by a rock!
Hey Man (03-28-2020)
Old 03-28-2020 | 04:15 PM
dawg's Avatar
dawg
Old 03-28-2020 | 04:32 PM
hdbob2006's Avatar
hdbob2006
How "unidentified foreign object" is that better?
Old 03-28-2020 | 04:38 PM
Hey Man's Avatar
Hey Man
FOD - Foreign Object Debris.
Architect (03-28-2020)
Old 03-28-2020 | 04:50 PM
dawg's Avatar
dawg
Stick with H-D belt. While in there, check your seals (shift shaft, tranny seals), IPB and race. Check to see how the comp is holding up and if any additional springs needed. You changing the pulleys too or just the belt?
smitty901 (03-28-2020)
Old 03-28-2020 | 05:54 PM
caulk04's Avatar
caulk04
I'm assuming it was a rock. I've only gone about 300 miles since I mounted two new tires (not my first time) and I've heard no weird noises. My last ride took me down a couple dirt and gravel roads so that's why I assume a rock got wedged somewhere. Whatever the case, it's coming apart so if something else is wrong I'll find it.
The belt guard is still there, but I can't see how it would protect the top of the belt. If it's not clear, the damage is only on the outside, the inside is still good.
Stock pulleys are staying, I have no desire to change the gearing. Had an 08 before and I much prefer the lower ratio of this 2011
​​​​​​​Since I've got time, but diminishing funds (Corona layoff starts next week) I'll likely start the tear down tomorrow.
Old 03-28-2020 | 06:44 PM
timbo141's Avatar
timbo141
Changing the pulleys was for the wear item factor not for changing ratios.
Rear pulley is aluminium, front is steel.
When new belt is installed new pulleys are recommended.
I can see leaving the front steel one with only 30k miles but the rear, make sure it shows no wear.
Cost and time involved changing belt, make sure pulleys are like new if not new.
Quick Reply: Belt. Laugh at my pain.
