CarPlay & PackTalk Bold
Old 04-19-2023 | 09:08 AM
Spartanden's Avatar
Spartanden
for some reason I no longer have access to the "old" Cardo Connector set up. I had that at one time and set my Packtalk to radio stations, and some other things....which I cannot recall, but know that I did some updates/changes on this. I cannot find this cardo connector, and not entirely certain how I can make changes now.
  #212
Old 04-19-2023 | 09:16 AM
DWKen's Avatar
DWKen
You might check your PackTalk User's Guide (manual). I'm pretty sure you can program FM radio channels without being connected to a computer. I don't use the FM radio feature any more, so my latest experience is years old. But I think the manual tells you how to do it.
  #213
Old 04-19-2023 | 10:31 AM
Spartanden's Avatar
Spartanden
I understand about the local stations.... have couple on my packtalk now. But we take rides outside of the local radio station areas....just want to be able to tune in to other stations when outside of normal. I do appreciate all your feedback...it's good for me as a refresher!! And I do have the locals tuned in, but want to expand my area more!!!
Got bunch of honey-dos so may not be able to do much with bike today....but you guys have given me good info and refreshed me, so I will put that to use!!!
Thanks!! And I'll let you know what I ended up doing and how things work out. The main thing is to be able to take a ride with new helmet, in-helmet speakers and packtalk and see how they work together!
  #214
Old 04-19-2023 | 11:05 AM
DWKen's Avatar
DWKen
Well, that's a bunch different from your first post.
You'll probably need to buy a Bluetooth transmitter (they're cheap, look on Amazon), plug it into your BoomBox audio out, and pair/connect to your PackTalk.
The Bluetooth transmitter will turn the BoomBox audio into Bluetooth that you can connect to and hear on your PackTalk. Any audio on your BoomBox will be transmitted via Bluetooth to your PackTalk.
Ken
  #215
Old 04-20-2023 | 02:08 PM
Parrothead1809's Avatar
Parrothead1809
Originally Posted by RiderX
There is a setting in the GTS radio where you can redirect audio to your headset or at least disable it on the bike's speakers. I am not in front of my bike at the moment so I am not sure what it is EXACTLY. I believe it is in the Audio section of settings.
Just making that one change didn’t fix it, so I went though the power-on process you detailed in your first post and Presto! It Worked! Not sure exactly which bit got flipped but it proves one again that your procedure is spot on. Thanks again!!!
-PH
  #216
Old 07-29-2023 | 04:27 PM
Parrothead1809
Just another datapoint: I just did a firmware upgrade from M21.20.28.00 to M23.22.27.00 and am glad to report no loss of functionality. As a matter of fact, maybe I didn't realize this worked in the past, but holding the Voice Command button now wakes up Siri for a command. Of course "Hey Seri" still works along with all the "Hey Cardo" commands.
It does seem that I have to say "Hey Cardo Music On" and it replies "Music Off" and plays music through my headset. But I think that's a software toggle switch that somehow got messed up. Minor.
PS: I didn't update the maps since I normally use Google Maps. Although it's nice to have a back-up map program handy when I'm camping and "off the grid", $150 for the updates gave me pause.
  #217
Old 07-29-2023 | 05:12 PM
RiderX's Avatar
RiderX
Firmware updates will not break CarPlay functionality - they never have and never will. The only thing you have to be careful of is when the HD dealership connects your bike to Digital Tech and makes changes. I have heard of cases where a tech makes a change in Digital Tech, and breaks CarPlay. If this happens, you have to take it to an independent shop and have them flash it with the 3rd party equivalent to Digital Tech, the name of that software escapes me at the moment.
  #218
Old 07-29-2023 | 05:20 PM
DWKen's Avatar
DWKen
Did you know that the command to turn Music on or off is simply "Hey Cardo Music". It's a toggle. I learned this just over the course of our last 5,000 mile motorcycle camping trip from which we returned last Sunday. It's actually in the User's Guide and videos. Prior, we've all been trying to get it to recognize "Music On" or Music Off". Just "Music" and if it's ON, it'll turn off and if OFF it'll turn on. Pretty much total reliability.
The following 2 users liked this post by DWKen:
lefty33 (07-31-2023), TOHOG (07-30-2023)
  #219
Old 07-29-2023 | 06:08 PM
Parrothead1809
Strange - I see "Hey Cardo Music [On | Off]" in the quick reference. I bet they just rev'ed the firmware at some point... That's the problem with documentation: It's out of date the second it's written !
Thanks!
  #220
Old 07-29-2023 | 08:46 PM
DWKen's Avatar
DWKen
Thanks!
yeah, me too.
But I stumbled across the Music Toggle in documentation somewhere while on the trip and found it to be absolutely reliable! It was just as reliable as "Hey Cardo Battery Status" which has always worked almost flawlessly.
The five of us started using the "Music" toggle while riding.
Ken
lefty33 (07-31-2023), Parrothead1809 (07-29-2023)
Quick Reply: CarPlay & PackTalk Bold
