Center stand
Old 02-29-2020 | 08:02 AM
leachman's Avatar
leachman
I had one on my 05 ultra and have one on my 08 ultra. EZ UP Center stand will stand(no pun intended) behind their product. I had an issue and they had me send back to them and instead of rebuilding mine they sent me a brand new stand at no charge.....I use mine on trips when filling tank to get most out of the tank. I will also use it if in tight spots as someone else has mentioned. I also like using it for changing fluids or when working on adjusting primary clutch pack....
Uncle Larry (02-29-2020)
Old 02-29-2020 | 10:50 AM
Keithhu's Avatar
Keithhu
Originally Posted by rnl_1200C
do it need to be anchored to the cement floor ?
It do not. It install to bike.
The following 3 users liked this post by Keithhu:
Campy Roadie (03-01-2020), ratpick (03-05-2020), rnl_1200C (03-04-2020)
Old 02-29-2020 | 09:54 PM
langwilliams's Avatar
langwilliams
My friend bought a condor bike dolly. It holds the bike up straight an makes it super easy to move around but it was a little pricey. I have rear air ride an I was looking at the electric center stands but they are price an a little more of a pain to install...if I come across a deal on a used center stand I might pick it up to try to modify it an cut it down for a manual stand for the air ride.
Old 03-04-2020 | 02:10 PM
cajun1957a's Avatar
cajun1957a
Neggy, im looking for a center stand for my 2003 RKC. What brand do you and how is it?
randy
Old 03-05-2020 | 12:14 PM
trennmaschine's Avatar
trennmaschine
3rd Gear
If you're looking for _only_ oil and other minor service, get a jack. Harbor Freight (under $100) does a great job. If you want something for 'on road' use, such as fueling up, stopping for a drive-in movie (yeah, i've done this), or parking in a tighter than normal spaces, the Wheel Dock seems to be the ticket. Currently runs about $270 and is about a half hour to set it up (that includes finding the wrong tools, throwing those across the garage floor and then getting the right ones and another beer).
Old 03-05-2020 | 07:28 PM
vistavette's Avatar
vistavette
Originally Posted by Silent Glider
I also have Ez-Up.
works great.
10 mins to install.
The stand has one bolt on 2009 and up bikes. Are you including drinking a couple beers in that 10 minutes? 🤪
Old 03-06-2020 | 07:03 AM
Hecklerboy's Avatar
Hecklerboy
Does this center stand affect using a jack (J&S) to lift the bike?
Looks to be a good option when washing or just piddling with my SG.
My other bikes have center stands and it makes working on them easier when a jack isn't required.
Old 03-06-2020 | 07:07 AM
vistavette's Avatar
vistavette
You can use a jack with the EZ-UP stand, but I found it easier to remove it when I wanted to use the jack. It's literally one bolt and takes just a moment to take off or put on.
Hecklerboy (03-06-2020)
Old 03-06-2020 | 07:16 AM
heybaylor's Avatar
heybaylor
randy
I have one off my 2004 roadglide, p/m me for details
Your profile does not allow me to p/m you
Old 03-08-2020 | 06:51 PM
cajun1957a's Avatar
cajun1957a
I found one used for $170 Canadian and it works just as said although first time was a tad tricky. Ez-up is what they say and it is.
randy
Djcamis
2014-2023 Touring Models
26
03-04-2020 02:55 PM
lionsm13
04-15-2014 06:28 AM
jgreg65
12-22-2009 05:27 PM
6speed
04-12-2007 09:46 AM
cemax12000
11-06-2006 05:54 PM
Quick Reply: Center stand
