Here we go. Asking a newb question exhaust. Stock ac no tune m8
Well. Got hooked up with a cheap *** danmoto 2 into 1. I have a 2017 m8 road glide.
I have not purchased a intake nor had my old powervision relicensed to this bike.
anyone know if the new m8s are ok if you just run a full exhaust and leave the factory intake with no tune
I know prebious models you could do either intake or full exhaust with no tune. But you couldnt do both intake and exhaust without tuning your bike.
basically i wanna bolt this pipe up and run it for a bit with stock a/c and stock tune.
Is that ok? I have no idea about these m8 motors
With closed loop ESPFI and riding around mostly within a quarter throttle condition with NB O2, it won’t hurt anything at all. I tested this with my own bike (‘19 EGS) and the performance difference without retuning was substantial. Looking at the AFR and other charts, there’s plenty of range within the factory tune to accommodate uncorking the intake and exhaust.
I didn’t retune until I changed the factory headpipes but I’m still running the factory NB O2. I was thinking I’d re-cam but I have gobs of low end torque the way I’m set up now, but I will be going WB O2 with the Auto Tuner pretty soon because I’ll be 10,000 feet higher in the Summer.
MB
MB
MB
Actually, comparing the Air/Fuel Ratio (AFR) charts for the actual tunes, they’re not “too lean” from the factory. There are times the ECM will command a lean or rich condition, but it’s based on numerous variables but never during a cruise condition. And again, I’ve tested this myself and compared the numbers. Additionally, without changing the air cleaner, you’re not allowing any more air into the engine than what was allowed prior to changing the exhaust, so the tune doesn’t need to change.
MB
MB
I also was seeing reports tgat the m8 is not lean from the factory.
Hm, interesting. I dont know enough to argue lol, but some really reputable tuners on the M8 facebook group have said they've dyno'd them and theyre very lean from the factory. I would tend to believe that considering all the EPA emissions stuff.
My stock bike/pipe gets hot as hell which also tells me its lean, but I've also never had a bike with a cat before.
I am personally waiting to do tune, AC, and pipe all at once, but maybe I'm just paranoid.
If not lean, I would think it'd run poorly? My 08 did just from switching to duals to 2-1 without a tune.
If you do go forward, come back with your results, now I'm curious!
MB
