Tour Pac Wall Mount
Do a search here on the forum, many posts about it. https://www.hdforums.com/forum/touri...l#post15346213
It's stupid simple. I used a couple of pieces of angle iron, 3/8" all thread and some CPVC. I drilled two holes in each piece of angle iron that were spaced to match the mounting pegs on the bike, then inserted the 3/8" all thread through the angle, through the CPVC and through the second angle. I used nylock nuts on both sides and mounted it to the exposed studs in my shop. Easy peasy...
i went even simpler. i used 2 shelf brackets and a small piece of shelf board. the shelf board was small enough to fit inside the tour pack mounting rack, so all i have to do is just sit the tour pack 'on the shelf'. sits horizontally, so if you have anything you need to store inside the tour pack, you've got that room. put it up high enough that i don't hit my head on it. then i use a fitted crib sheet to cover it all up to protect it from dust.
BelchFire (02-07-2020)
tgaetto
03-29-2016 10:46 PM
