AdvanBlack Lower fairings
while the advan lowers can be a good value, there are a couple of things to be aware of. first, they aren't quite as thick as the hd oem. then there is the glove box. the hd oem are 'rubberized' while the ab are just a textured plastic. the issue above of the snaps won't apply to you since you have a rushmore, but on the rushmore style, you have the door opening mechanism that is prone to failure. mine did, both the gear mech and the door latch broke. not a problem though, i just replaced the door catch with a couple of rare earth magnets and it holds it pretty securely. the vent door opening/closing mech isn't as smooth as the hd either. mine is stiff enough that i cannot adjust it while riding, i have to pull over to do it. but that's a rarity, i usually have it adjusted where i want before i start.
would i buy the takeoffs again? sure i would. the lowers are down low, and close to the road so they are hit with all kinds of road debris. either harley oem or takeoff, they will get abused. i can buy 5 or 6 sets of the takeoffs before i've spent what hd charges. (i got mine off of amazon for $100. i didn't need them painted as my bike is vivid black so that cut down on the cost substantially)
Nice looking RG (I like the chrome pipe on the otherwise blacked out bike). Just to confirm, are your from AB or a different Amazon product? If that latter, can you link which ones you bought? Any other parts needed to install? I am thinking about lowers but not sure I will like them so cheap from Amazon would be ideal and I can upgrade (if needed) after a year of testing them.
thanks. mine are not advan, they are off of amazon, but are virtually identical to the advanblack. i know this because i bought a set of the color matched advans for my wife's bike.
here's a link to the ones i bought:
the only thing i bought to install these was the lower p-clamp. the one that comes with the lowers is a little smaller.
here's a link to the ones i bought: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
what seat is that?
I also recently ordered and installed the advanblack lowers on my 2017 Street Glide. Ordered color-matched in Velocity Red Sunglo and the paint was absolutely perfect match! Easy install, just don't over tighten mounting bolts as like all lowers, they're all plastic. Look great, and saved a bunch over HD lowers. So far I haven't had any issues with the latch mechanism on the glove box doors. Love em!
