New Solo Seat from Sargent
Old 01-18-2020 | 08:56 AM
Hammerdown77's Avatar
Hammerdown77
Originally Posted by AliensilverFXDBI
Thanks, I figured the strips weren't part of the seat just curious where I could find them.
Aren't those trim strips on CVO bikes?
Old 01-18-2020 | 09:36 AM
Steve N,'s Avatar
Steve N,
Originally Posted by Hawg Runner
Interesting, but what about us folks that the stock length seat is fine, do not need a reduced or extended reach.
Originally Posted by Hammerdown77
What they're calling "short reach" (18") appears to actually be further back than the factory seating position. I believe it's typically 15.5 or 16" back for most H-D OEM seats. Then in another description they say the two available reaches are long (18") and short (14"). So that's different than the picture and the description in the seat link itself. Probably need to call them to clarify.
I wondered the same thing, so I went out and measured the the stock seat length on my RK. It's 18" from nose tip to the back of the saddle (as Sargent shows how they measure theirs), so in my case, the 'short reach should work. So that's the seat length. The seat position (fore or aft) may or may not be different from stock. I didn't notice the other description using 14" & 18", so yeah,,, I think giving them a call before ordering would be a good move.
Old 01-18-2020 | 01:30 PM
steelerdude1's Avatar
steelerdude1
Originally Posted by Beaux
Spitting image of the CVO seat .....
agreed.
Old 01-18-2020 | 02:06 PM
AliensilverFXDBI's Avatar
AliensilverFXDBI
I think so. Can non CVO owners buy them?
Old 01-18-2020 | 02:43 PM
skratch's Avatar
skratch
yes, those are the trim strips that fit under the passenger pillion on the cvo bikes. and yes, you can buy those. at $30 each from your local or a little less from a discounter.
and I also noticed that the sargent seat looks like a spitting image of the cvo seat that I bought and put on my 2019. but looks can be deceiving. it may look the same, but does it 'feel' the same? would be interesting to find out. personally, if i'm going to spend that kind of money, then I would go to the corbin factory and do their ride in program and have a seat custom built for you.
Old 01-18-2020 | 03:39 PM
Dynamick's Avatar
Dynamick
Not a Moderator!
Website says a backrest for this seat is "in development", once they release that version I'd seriously consider one. I had a Sargent seat on my Suzuki Bandit and it was a huge improvement over the stock seat. Then again, sitting on a milk crate would have been an improvement.
blap (01-18-2020)
Old 01-18-2020 | 06:04 PM
Hammerdown77
Any of you guys have a CVO seat you could measure from tip to top edge of the seating area to see how it compares?
Old 01-18-2020 | 06:47 PM
Hammerdown77
I only get 17" on the SG/RG seat that came on my '19 Road King. Thought the stock RK seat was 1" shorter than that, 16". I get 18" if I go back to the seam in front of the backrest slot.
Either way, a claimed 20" (if real) for the extended length is probably the longest seating area I've seen on an aftermarket solo seat, apart from custom.
Old 01-18-2020 | 07:33 PM
Gary1's Avatar
Gary1
I have a mustang wide solo and it's great.
Old 01-19-2020 | 09:33 AM
foxtrapper's Avatar
foxtrapper
Veteran: NavyVeteran: National Guard
even with that, I’d want an overhead picture, so I could see the seat pocket in relation to the side rails. A whole lot of the aftermarket “close” seats actually aren’t.
blap (01-19-2020)
Quick Reply: New Solo Seat from Sargent
