SG Bag rubing
Old 07-17-2007, 10:27 PM
chopperz71's Avatar
chopperz71
chopperz71 is offline
Default SG Bag rubing
I just got back from a ride from OK, TX, and NM. One of my bags sits lower than the other and rubbed some of the paint off of the cover. Took it by a dealer and they said that the warranty doesn't cover paint. But they couldn't figure how to get it to set like the other side which is about 3/4 of an inch above the cover. Any one else have this? Any ideas?
Old 07-17-2007, 10:46 PM
notorious's Avatar
notorious
notorious is offline
Default RE: SG Bag rubing
Perhapsyou have lost the rubber bumpers on the bottom of the bag that sits on the support or the rubber seal on the inside of the cover.
Old 07-17-2007, 10:51 PM
chopperz71's Avatar
chopperz71
That was my initial thought. But not the case.
Old 07-18-2007, 01:14 AM
fatboylust's Avatar
fatboylust
fatboylust is offline
You might want to remind your dealer that theHARLEY-DAVIDSON MOTORCYCLE PREDELIVERY AND SETUP MANUAL says that they are to:
"INSTALLING SIDECOVERS AND SADDLEBAGS
Check that each saddlebag is firmly seated on its saddlebag
bottom support rail. Check that adequate clearance exists
between saddlebags and sidecovers. The front and rear
mounting brackets of each saddlebag have slotted mounting
holes (on the bracket ends which attach to the motorcycle) to
allow for vertical adjustment of the saddlebag. If adjustment is
necessary, loosen the bolts which secure the saddlebag
mounting brackets to the motorcycle. Press down and to the
rear firmly on closed saddlebag, and then tighten the bolts to
60-96
in-lbs (6.8-10.8 Nm) torque."
The factory warranty may not cover paint but their failure to properly assemble the bike is their responsibility to repair/correct.
FBL
Old 07-18-2007, 01:57 AM
mtpoland's Avatar
mtpoland
mtpoland is offline
Most definitely- fatboylust is right on the money. Call the HD customer service center and report the issue to them and explain that the improper set upby the dealeris what lead to the damage. What ever you do, DON'T SETTLE FOR THEIR BULLSH*T. Be extremely pissed off and demanding. We pay too muck f**king money for these bikes to have to put up with bullsh*t. Persistance usaully pays off.
Old 07-18-2007, 08:54 AM
GOSTAZ's Avatar
GOSTAZ
GOSTAZ is offline
I had this issue... called Corp to get the monkeys to do their job. Sundowner seat is famous for doing this. Bike ordered with the Sundowner seat on it...
Old 07-18-2007, 09:48 AM
Garemlin's Avatar
Garemlin
Garemlin is offline
Mine did the same thing. Even though it wasn't covered under warranty the SM got a custom painter they use to repaint my side cover free of charge. It all comes down to the bags being adjusted correctly at set-up.
Of course if you took your brackets off for any reason, such as to install docking hardware or whatnot, chances are they are not lined up exactly like they were. There is alot of fine tuning involved with those brackets to find just the right spot where the bags will sit right in their supports and still not rub the side covers.
Old 07-18-2007, 09:53 AM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
GRRRREAT post, FBL--you absolutely, positively nailed it.
Old 07-18-2007, 12:38 PM
chopperz71's Avatar
chopperz71
Thanks for the help guys.
Old 07-18-2007, 02:42 PM
ssihogdog's Avatar
ssihogdog
ssihogdog is offline
ORIGINAL: chopperz71
B/S on the warranty! Just got my left lid replaced and dealer called me to let me know the sidecover was in - yes, under warranty. I don't know who paid for it, dealer or HD, don't care -- it wasn't me. While they were at it, they put in some spacers to ensure it doens't happen again. Oh, and they immediately adjusted the bags when I first took it back to them. This was at the 1K checkup.
Ditto - call HD if your dealer won't help you.
Quick Reply: SG Bag rubing
