Kuryakyn LED lights??
I purchased LED smoked front (#4825), rear(#4827) & Deluxe tailight (#4974).
The taillight works fine.
The rear TS works fine.
but the front TS when plugged in flash very quickly. I believe I need to install the load equalizer??????
I read the instructions....but still don't know where & how to install the L.E.
any pictures of where & how this install goes????
Currantly my front fairing is off (changing speakers & amps to Hawg-wired) if that will help the situation...
Also, can I install the turn signal, brake light combo adapter with these LED lights I purchased?
Thanks
Rick
Thanks
Rick
RE: Kuryakyn LED lights??
" Also, can I install the turn signal, brake light combo adapter with these LED lights I purchased?"
dealer said i had to buy a different brake light combo adaptar adaptar then i currently have going on my stock setup to use wuth the kuryakyn LED and license relocate gig im doing.
FYI
I called Kury, very helpful...
1st, told me to purchase a load equalizer.
then I inquired aboutthe brake, turn light combo. Kury said, to purchase there brake, run, turn light combo,no need to purchase the seperate load equalizer, because one come in this kit. It's a plug and play adapter. They also mention to install the load equalizer under the seat, due to the excess heat from the load equalizer.
Glad I called them. Extremely helpful.
METALKAT
04-10-2010 06:26 PM
4827, classic, controller, equalizer, harley, install, kury, kuryakyn, kuryakynled, led, lights, load, spotlights, touring, ultra
