Whisteling Fuel Tank Problem FIXED
Old 07-16-2007 | 08:33 PM
rschoepf's Avatar
rschoepf
Default Whisteling Fuel Tank Problem FIXED
For any of you folks that have noticed a whistle while turning your bike on and off I found the answer. About a weekor so ago my 04 FLHRI Road King started to make a "NEW" sound. The usual winding up of the fuel pump was replaced with an added whistling sound. The bike ran fine for a few days but then the idle started to get wierd and performance was up and down. I researched the sound and even asked for help on this site. Well since I turn my own wrenches and knew the new sound could not be good so I got into it. Seems that thefuel line inside the tank that goes from the check valve to the regulator was rubbing on the inside of the tank. That in turn wore a hole in the line causing a leak and the whistel. Since this line is pressureized at 58 lbs. it just stands to reason that my performance would be hampered. What pissed me off was that Harley knows about it and didn't do anything about it! They did however modify the part with a slightly shorter line to minimize the rubbing. The line is still made like crap, only out of cheap plastic and will run you $40.00 plus clamps and the canopy gasket and 10 new Torx #20 sealing screws. Parts totalled about $63.00 To have this done would cost someone about $300 at Harley. Don't panic if when you shut down you hear a quick puff this happens allot and is not a problem. The problem is the whisteling when the pump is first turned on. You may last 6 months with this problem or 6 days.
[IMG]local://upfiles/37258/94E6A6360FA448FD89C3554FFA2C86E9.jpg[/IMG]
Old 07-16-2007 | 08:53 PM
azhole's Avatar
azhole
Default RE: Whisteling Fuel Tank Problem FIXED
Thanks for the insight!
Old 07-16-2007 | 09:43 PM
rschoepf's Avatar
rschoepf
My pleasure, thats why we are all here to learn and to share. I remember the days when I owned a Honda 1100 ACE (hey it was a great bike) I got more info and gave more on the forums then any shop. Not to dis the HD mechanics in any way, but they are not always willing to give away trade secrets and free advice.Ride safe...Keep the Rubber on the Road
Old 06-30-2008 | 02:56 PM
OregonRoadKing's Avatar
OregonRoadKing
I guess this is another good reason to get the service manual. This may be the problem I've got, but I'm not sure how to get into something inside the tank.
Old 06-30-2008 | 06:54 PM
garyhendley's Avatar
garyhendley
i have read about the same problem on this forum i guess we all have to look
&nbsp\\;
into our gas tanks ?? chock up another harley quality product what the f n is next??
Old 07-01-2008 | 03:45 PM
OregonRoadKing
Just checked with the dealer. My problem is the result of H-D's poor design and cost cutting cheap-assed ... sigh. The fuel filter part is on order and should be here soon...hopefully. Also hopefully, the new design is done right and not just as cheap as possible. There is no service bulletin as H-D is hoping to get away with as few fixes as possible. So far, the part is back ordered due to so many failures. Dealers are getting an allocation. Hope I get one.
Old 07-01-2008 | 05:09 PM
rounder999's Avatar
rounder999
How can you check this?
wedgemoose
07-13-2020 12:51 PM
Jason Meyer
09-12-2016 07:54 AM
Ratbag67
06-16-2015 08:06 PM
badbags
03-23-2011 07:49 PM
rschoepf
18
09-25-2007 12:01 PM
Quick Reply: Whisteling Fuel Tank Problem FIXED
