HD HID Halogen High Beam Replacement
I did a search but can't find where this has been asked or answered in the past. I have the HD HID (can't get it adjusted high enough but that's another question) headlight. What I want to know is what wattage is the halogen highbeam and whether it can be replaced with a 100w bulb?
I've upgraded my passing lamps to halogen, replaced the 35W with 55w bulbs and wired them to stay on with the high beams.
Just trying to light up the night.
RE: HD HID Halogen High Beam Replacement
The high beam lamp with the HID set-up is just stock. The HID only replaces the low beam... so, the Harley replacement lamp is #68096-04 which I believe to be a 55/60W.. I replaced mine with a bright white PIAA 100W. I also upgraded to halogen and wired my passing lamps to stay on all the time and regularly ride with heated gear in the winter and have had no problems either with the charging system or the lamp lenses.
Side note: When the sealed-beam halogen passing lamps bite it you can just remove the rubber boot from the back of the lamp and put in an inexpensive replacement lamp rather than buy the MOCO's $30+ replacement .
I would suggest that you do not go with a 100watt bulb! To be safe, go no more that 60/55 watts for HID. Anything higher will risk melting wires and/or damage to your electrical system!
ORIGINAL: Sheep
ORIGINAL: casique
Is the HD HID kit plug and play or do you have to cut wires? Thanks.
ORIGINAL: Crazie
Dave,
The Low beam on the HID unit is a D1 35 watt. The high beam is an H8 35 Watt. Hella makes a 55 watt H8, but have not found one yet. However the H11 comes in 55, 80 and 100 watts and the base , with some minor filing fits in.The filiment height is identical so the beam focus works out ok. I use the H11 55 watt and it helped some. I would be hesitant to go much higher as the heat buildup may have some effect on the (expensive!!) plastic housing.
Tom
Tom
ORIGINAL: tcfamy
Dave,
Tom
Dave,
Tom
