Replacement footboard inserts
Old 11-04-2019 | 09:04 AM
1of2's Avatar
1of2
"Moderator"
Default Replacement footboard inserts
I am hard on my foot boards. For some reason I push them sideways and eventually the rubber cushions on the bottom rip and the inserts come lose. Is there a way I can replace the rubber without having to replace the whole insert? My inserts are still in good shape and are now discontinued and I would rather not switch to a different style. Thanks for any help.
Old 11-04-2019 | 09:09 AM
eighteight's Avatar
eighteight
Find some hard rubber buttons and glue them on ?
Old 11-04-2019 | 09:11 AM
Bubba Zanetti's Avatar
Bubba Zanetti
You talking about the rubber "****" that pushes through the hole and holds the insert onto the board? If so I cant think of any good way of repairing that. Maybe you could run a bolt with a flush head through it? But that might look goofy...
Old 11-04-2019 | 10:17 AM
OlAndrew's Avatar
OlAndrew
I hadd the same problem. Stuck em back together with some good contact cement. 6 months and several thousand miles, and still holding fine.
Old 11-04-2019 | 10:21 AM
grbrown's Avatar
grbrown
Red face
Perhaps some countersunk screws, with self-locking nuts?
Old 11-04-2019 | 12:07 PM
1of2's Avatar
1of2
"Moderator"
I think this is the best answer. If the rubber can not be replaced I might as well try to repair it as good as I can. If that doesn't work then I will have to replace with something else.
Thanks for the replies. Very helpful.
Old 11-04-2019 | 12:15 PM
Fireball Jack's Avatar
Fireball Jack
What are you doing to them that kills them?
Old 11-04-2019 | 12:43 PM
Jaftica's Avatar
Jaftica
you can find new take offs cheap enough on flea bay and craigslist.
Old 11-04-2019 | 12:52 PM
nobodyknowsme's Avatar
nobodyknowsme
Or the classifieds here.
Old 11-04-2019 | 01:13 PM
Bubba Zanetti
They wear out after a while and dry rot or deteriorate. I replaced a set on both of my Road Kings when they got to be somewhere right around 8 or 9 years old.
Quick Reply: Replacement footboard inserts
