Heat off of 2012 Ultra with lower farings
Old 10-20-2019 | 07:46 AM
PukinDogs's Avatar
PukinDogs
6th Gear
Default Heat off of 2012 Ultra with lower farings
Doing some test rides on different models, yesterday rode a 2012 Ultra Limited that had the lower fairings installed. I was surprised at the heat I felt on my thighs when at slow speeds or at a stop. Bike also had the heat guards installed. My question is should I expect the same amount of heat to come off of it with the lowers removed?
Thanks
Old 10-20-2019 | 07:50 AM
Iceman24's Avatar
Iceman24
Yes, but not as bad while moving...bike's running hot (lean). Guessing it had OEM exhaust (header) w/ CAT...??
Old 10-20-2019 | 08:07 AM
EdwardK's Avatar
EdwardK
Iceman24 is probably right. I'd like to also ask, did you look at the adjustable vents on the lowers? They may have been closed by mistake.
I ride a Road King most of the time with out lowers. I doubt I would ever add them but I wouldn't think of taking them off my Limited either. I like the wind and rock protection on my lower legs.
Old 10-20-2019 | 08:33 AM
PukinDogs's Avatar
PukinDogs
6th Gear
iCEMAN, Unknown, I did notice it had screaming eagle exhaust. I was not looking "at this bike" to buy, but just to see if I liked the riding position, how it rode, if it talked to me etc etc. First time on a Ultra and it was nice,
Edwardk, no I did not even think to check. This time of year the heat was not bad, but during summer I would bake, I am also pretty short legged so I was 'hugging' the bike at stops.
Thanks for the input.
Old 10-20-2019 | 09:08 AM
Notgrownup's Avatar
Notgrownup
I swapped my motor on my 07 FLHTC from 96” with Cams to a stock 103HO from a 14 Street Glide...It’s hotter and I have a catless 2in1 exhaust with a decent tune. It’s hot with and without lowers, I take my lowers off in the summer. I am reinstalling them today as well as my deflectors for a trip to the hills Thursday...I like the extra airflow in the summer...crotch cooler from Captain Itch.. They are hot air cooled motors....
Old 10-20-2019 | 09:30 AM
TheMurf's Avatar
TheMurf
Default 012 Ultra heat
I have a 012 Ultra. I always ride with the lower vents fully opened up to allow for more air flow. I also killed the cat in the header pipe,which helped..They are lean running and that produced more heat for sure.
Old 10-20-2019 | 09:53 AM
PukinDogs's Avatar
PukinDogs
6th Gear
Just to be clear are you saying that the 96 ran cooler? Thanks
Old 10-20-2019 | 11:32 AM
Notgrownup's Avatar
Notgrownup
Yes and a good tune riches the air fuel mixture a bit and cools it off.
Old 10-24-2019 | 09:00 AM
Geezr Glidr's Avatar
Geezr Glidr
PukinDogs, I had an 09 Classic that ran great. When I traded & bought my 11 Limited Ultra, I was in panic mode thinking something was wrong because of all that heat. Then I found out about the catalytic converter in 2010 (I think) and newer. As soon as I replaced the head pipe (I did Vance & Hines Power Duals) the heat "disappeared." Well, not actually disappeared, but back to what I'd call "normal heat." I think it won't matter if you have vents open near lowers, no lowers, or fans, it ain't gonna make the heat go away. You need to get a catless header. I now have a 16 Limited Ultra, and even before I rode it away from the dealer, I had Power Duals put on. That's the 1st thing I'll do to a new bike from now on.
PukinDogs (10-24-2019)
Old 10-24-2019 | 09:08 AM
PukinDogs's Avatar
PukinDogs
6th Gear
Good info, thanks!
Quik
Milwaukee Eight (M8)
17
02-28-2018 06:49 PM
Terrabella
10-11-2013 12:01 PM
ajay450
02-01-2009 10:15 AM
VaRanger
05-18-2007 02:22 AM
mcman
08-09-2006 12:54 AM
Quick Reply: Heat off of 2012 Ultra with lower farings
