Oil leak
Old 10-19-2019 | 04:29 PM
Cozz's Avatar
Cozz
Originally Posted by itchyjoe
Cozz, check to see if there's a lot of slop in your shift linkage. If so tighten it up by fashioning a thin shim to go between the rubber spacer and inner shift lever. That's what I did a few months ago (03 RK) and have been dry since. I guess hours of vibration on a loose linkage was a setup to cause a little seeping. May not work for you but something to try...I'm also very conscious of being easier on the shifters now!
Not sure where you are saying to put a shim, got a pic?
I checked the vent, it’s fine, no blockage. I dumped the Valvoline synthetic tranny oil and replaced with Lucas conventional. The Valvoline was like water coming out. Shifting better with the Lucas. Going out for a long ride tomorrow, i’ll See how it does. Indy said it should be much better with the conventional oil in it, rather than the synthetic.
Old 10-20-2019 | 07:05 AM
itchyjoe's Avatar
itchyjoe
On the attached pic it's between #9 & #39. I had an old rubber spacer (#9) and just sliced off a very thin section with a box cutter, slid it onto the shift shaft then reinstalled the shifters. If your new spacer is too thick, the screw securing the shifter won't slide through the groove on the shift shaft...so some trial and error on thickness may be required. There's now minimal play when I wiggle the gearshift lever (#27) in and out...and no more leak (yet!). Hope this helps; I can try to get a good, actual pic later if you want.
Cozz (10-20-2019)
Old 10-20-2019 | 07:48 AM
Dan89FLSTC's Avatar
Dan89FLSTC
That is nowhere near the shift shaft seal...
The seal being discussed fits into the transmission case, #18 in the illustration.
Cozz (10-20-2019)
Old 10-20-2019 | 10:01 AM
itchyjoe's Avatar
itchyjoe
Understood. And I surmised that maybe vibration in my overly loose shifter linkage was transmitted to that seal thereby causing seepage. Certainly worth consideration before replacing the seal.
Cozz (10-20-2019)
VINNIE JAMES
09-18-2010 04:48 PM
soft 02
09-02-2010 01:27 PM
FastHoss
03-29-2010 08:44 PM
2Shakes
Exhaust System Topics
04-11-2009 10:12 AM
BGHV65
10-21-2007 09:11 AM
Quick Reply: Oil leak
