May already be a answer somewhere but .......
Old 10-06-2019, 10:11 PM
Seclusion's Avatar
Seclusion
Seclusion is offline
Default May already be a answer somewhere but .......
I have a 2004 Road Glide. Problem I have is bike is dead. Battery is good. Only 2 months old. Has no power anywhere. NO LIGHTS NO GUAGES NOTHING. I turn to ignition I get nothing but when I turn back to off I here what sounds like fuel pump Or something activate and see gauges jump slightly a few times. I have changed all fuses in fuse block under side cover including the maxi fuse. Am I missing some somewhere? WHERE IS THE MAIN CIRCUIT BREAKER LOCATED ON AN 04 ROADGLIDE? Could that be it? Are there other circuit breakers I'm missing?I'm at a loss. Cant figure out why it does that only when I turn it to off position not the ignition position.This all started on a trip back from maine. I was riding and heard a small pop or something and saw engine light come on for a second then fo out. Bike started running like it was only on 1 cylinder. Tried to limp it home. Could not let off throttle at tolls or it would die. Tried to get home. Ut was almost out of gas. Had to stop. Shut bike off. Got gas . Turned key on
All gauges a d lights were on but when I hit start I heard a click. Turned it back off then tried again but when I turned key to ignition it was completely dead from that point to now
Old 10-06-2019, 10:21 PM
d_slat's Avatar
d_slat
d_slat is offline
How do you know the battery is good? Unless you've load tested it or measured the battery voltage in the bike with the key on, it and the battery cable connections on both ends of each cable are the #1 suspects...
Old 10-06-2019, 10:35 PM
Seclusion's Avatar
Seclusion
Ok point taken. I'm just assuming it's good since it is that new a d holds charge a d measures good when battery is on floor our of bike. Didnt see any issues with cables a anywhere unless I missed something
Old 10-06-2019, 10:43 PM
internet troll's Avatar
internet troll
internet troll is offline
Check your battery cable and your grounds. I know this sounds like an incredibly simple piece of advice, but experience tells me to start with the simple stuff.
(I had an old Camaro that was exhibiting weird starting issues. Starter would run and die. Give it a minute and it was fine. Crank it again and it would do the same.....after a day of messing with he starter and relays, I found the main battery terminal was old and loose..........)
Old 10-06-2019, 11:18 PM
Jersey Drew's Avatar
Jersey Drew
Jersey Drew is offline
Sounds like a loose ground or grounding issue
Old 10-06-2019, 11:40 PM
BB59's Avatar
BB59
BB59 is offline
Pull your battery charge it and load test it. I've d batteries fail in as little as 4 months. That's where I'd start.
plongson (10-07-2019)
Old 10-07-2019, 05:43 AM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
ignition switch is shot.
Captain Itch (10-07-2019)
Old 10-07-2019, 05:49 AM
Captain Itch's Avatar
Captain Itch
Captain Itch is offline
Sponsor
As mentioned above I have seen a lot of ignition switches fail ..
__________________
www.Captain-Itch.com
Old 10-07-2019, 06:00 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,866 Likes on 2,429 Posts
With no power anywhere the origins of the problem are very limited. Your bike probably has a main fuse, which may either have blown or be badly corroded. Having checked your battery condition as suggested above, check both ends of both main battery cables - dismantle each, clean and refit using dialectic grease.
Old 10-07-2019, 06:22 AM
steelerdude1's Avatar
steelerdude1
steelerdude1 is offline
I will guess a loose or corroded connection on the ground cable on the frame end. Either that or a bad ignition switch. - or maybe a lose wire connection at the switch.
Reading you’re description, I don’t think this is the case, but did you have your ignition switch out recently? Maybe the ignition cams got moved out of place? - Just a thought. . .
Quick Reply: May already be a answer somewhere but .......
