Chrome coming off wheels
I bought HD's custom wheels last year around March. I can't remember what they called them, I have the part number on the receipt. This morning I'm washing the wheels and the chrome starts peeling off!! Has this happend to anybody and if so what did you do to correct this problem? Thanks.
RE: Chrome coming off wheels
It's gonna require replacement - there's no way ta "fix" it, period. Chromin' of aluminum isa staged process requirin' sub-layers of different materials, an' it's gotta be done RIGHT at every step, or it peels. Bear in mind ah don't do platin' - ah supply the demineralized water needed ta make the process work in many areas. Lots of contract shops try to "shortcut" the process by extendin' baths and rinses beyond their rated replacement intervals, bettin' that by the time it's caught, the product is out of warranty - or they're outta business. Plating is as much an art as a science, an' it takes real work ta really do it right.
One other thang fer folks ta consider when lookin' at chromin' aluminum is that aluminum will flex - chrome will NOT. Durin' the course of a tire change, the rim itself is likely to flex, which can easily cause the bond of the plating to the base metal to fail. Likely won't show up right away, but over time it will.
