IOS13 CarPlay phone audio issue boom Gts
#61
So I'm a little late to the game but pretty much experiencing the same thing everyone else is: iphone 11 pro running iOS 13, bluetooth calls work just fine with Harley 30K headset on a 2020 Road Glide Limited with XM and WHIM modules. But as soon as I hardwire into USB for CarPlay, everything except phone audio for over 30K works. Took into dealership and we tried older phone and CarPlay worked just fine.
Just started riding new Harley but looking forward to fix.. Thanks.
GTS PackTalk Bold Update
woodreaux (05-07-2020)
#62
We did disable the microphone in Digital Tech just as you described and it did not resolve the issue for my iPhone 11 pro. We verified that CarPlay was working by plugging in the techs older iPhone and CarPlay worked perfect. We then tried a second techs older iPhone and his also worked. However, when we plugged my iPhone 11 Pro I was not able to have audio on phone calls. Just curious what iPhone do you have?
#63
I tweeted to HD too. they responded. This he twitter conversation is here https://twitter.com/harleydavidson/s...93832482496514.
please do reply on this so HD sees the interest in public.
All other features work like using Siri to text, or ask for directions.
#64
Also I have tested with the HD Brand Sena 20s and the HD brand Sena 30K, it does not work with either as far as phone calls, everything else works.
#65
I posted the wrong link above. I am going to make another quick reply with the exact details that I posted in a different thread. My apologies for posting the wrong link.
#66
This is my reply to someone from another thread. If you want to read the entire thread, which does contain good information, the link is below. Again, it is important to pay particular attention to section that outlines the order in which you should connect and turn on your devices. Just to be clear, I am using an iPhone 11 Pro Max in Midnight Green, the best color of course. Please let me know if you find this helpful.
'19 Boom GTS CarPlay Hack?
Originally Posted by RiderX View Post
I have done some additional, extensive testing and found answers to the very questions you are asking. The short answer is there is a specific process you must follow. Before beginning this process, certain settings and pairings have to first be in place.
The last preparation step is making sure that the Audio Routing options - for music, coms, and prompts are all set to headset and not the bike's speakers.
So at this point...
You MUST CONNECT & POWER ON DEVICES IN THIS ORDER.
I also want to add that all incoming and outgoing phone calls work perfectly and audio routing goes to the PackTalk speakers 100% of the time for both.
The only caveat to this setup, and I have not given up yet, is that if you say "Hey Siri, play Crazy B*tch by Buckcherry", it will play through your PackTalk speakers. I will only say, and I am sure you will not believe me and test for your self, there is no easy way without screwing up other functionality to get the audio to your bike's speakers. I digress. More to come on this topic in a future post.
Lastly, the only thing that remains to be tested, and I have every intention of doing so, is DMC communication mode with my buddies who also have PackTalk devices. I had odd an odd issue last summer, but I had not figured all of this out yet, wherein, I could not communicate with them in DMC mode unless I disabled the Rider Headset on the GTS. I am hoping since the above configuration already involves disabling the headset, I should be good to go.
I will be traveling to Nashville for the next few days so I will not be able to do any more testing until I return on Friday. In the meantime, give this a shot, and let me know if you find any of this helpful.
If anyone has any recommendations on funs things to do do in Nashville or wants to meet up for a drink, let me know.
- Make sure your PackTalk is paired via Bluetooth to your iPhone. Do this without the bike being powered on or without the phone being plugged into the bike.
- power on the PackTalk,
- go the the Bluetooth settings of the iPhone
- press and hold the bottom button the PackTalk for 5 seconds until in begins flashing rapidly (I forget the color combination)
- look for the PackTalk bold on your iPhone and select it to pair it.
- confirm pairing is successful
- turn off your PackTalk
- power on your bike
- go to 'wireless headset setup'
- make sure rider headset is set to disabled
So at this point...
- Your PackTalk has been paired to your phone but your PackTalk is powered off
- There are absolutely no pairings between your phone and your bike or your PackTalk and your bike (if there were, they should have been deleted or 'forgotten' by now)
- Your bike is powered off and your phone is not plugged into the USB port of your bike
- All 'Audio Routing' for music, coms, and prompts are set to the headset and not the bike's speakers
- Make sure you have no audio of any sort playing on the iPhone. In fact to be safe, close the Music app on the iPhone altogether.
- Plug the iPhone into the USB port of the bike.
- Power on the bike and wait a few seconds for the CarPlay icon to appear or until the GTS goes to the CarPlay Screen.
- If music starts playing, sometimes the bike remembers the status of CarPlay when it was last connected, pause it immediately, either on the CarPlay screen of the bike or the phone itself, unplug the phone from the USB port on the bike, shutdown the bike, and start from step 1 of this section again.
- Power on the PackTalk.
- Listen to the PackTalk speakers to hear the welcome message and the message that says your iPhone is connected.
- Wait about 10 seconds, at the most, for all of the connections to establish and settle down.
#67
There is a simple fix for everyone having this issue. I have documented the exact details and steps on the thread in the link below. The quick version is have your dealer hook your radio up to Digital Tech and have them disable the microphone option in Car Play. Do not use the WHIM at all, just pair your phone to your headset, and connect your iPhone to the bike via the USB cable. Phone audio will work over your headset; even 3rd party headsets like Cardo PackTalk.
#68
#69
All this information is fine but it does not fix the issue with iPhone 11 and CarPlay phone audio not working issues. How do you communicate with the CB radio without using the Boombox? Anyone can connect a phone to a Bluetooth headset so this is not really a workaround at all. Apple and Harley-Davidson need to get the problem ironed out and work with the iPhone 11’s using the wired mic or the WHIM Bluetooth systems
FLSTFI Dave (03-06-2020)
#70
If you have a PackTalk bold, you can just say 'Hey Siri' and use the mic built into your headset. Even on another brand of headset that has a button to activate Siri, most all do, you can hit that button and then use the headset mic to speak your command. I am not sure why you think you are losing microphone functionality. You are only losing the voice activation button functionality on the bike itself.
you would have to be losing functionality if you disable something.
