Headers or Slip-ons
Headers or Slip-ons
I have a 2019 Road King Special - I want louder pipes, so was considering slip-ons - but I've also noticed several posts where people have gone to the Bassani Down Under Headers - are headers really worth the extra money? What benefit do you get from them - I guess louder pipes, less heat? Thanks.
So , you’re saying it sounds like a herd of *****?
The following 2 users liked this post by eighteight:
Captain Grego (06-27-2020),
touchdown (06-23-2020)
So since you are considering headers i assume you don't care about HD warranty. Having said that. i believe you'll be better off getting the OEM header de-catted and spend the money on some 4 1/2 inch slip ons. RCX, S&S MK45, Reinhart new 4.5's, etc. You should definitely tune it once you do. You should be getting a lot of opinions soon. And go...
If you don't care about your factory warranty then replace your header while doing mufflers.
Just so you know pretty much every slip on muffler will kill your tq and even a good tune and a map won't bring it all back. That's reality. The M8 doesn't really wake up until you do a cam swap. I went with fuel Moto and tunable inserts were a must if you're expecting performance and not just sound.
If just doin
If just doin
I just had the following work done, after that list I will call my my observations:
1. Bassani headers
2. Tab Bam sticks 4.5" with Zombie baffles
3.Harley Torque cam
4. Screaming Eagle Tuner and tune... sort of.
Bike sounds great, I think. Heat was really bad on the right side but new headers fixed that issue
HOWEVER I HAVE ISSUES NOW -- I was getting a really loud pinging noise on acceleration. The tech had to back off the tune. He said the issue is that there is not enough back pressure and it was causing a vacuum and putting pressure on the exhaust valves.
The tech HATED that the dealership sold me the Bassani pipes, not only sold them but recommended them.
So to fix the issue, I hope... I ordered a set of Tab 2.5" baffles; to add some more back pressure. If that fixes the issue, I will have the tech add some tune back in.
All this to say watch out on too much free flowing pipes. But again, I think it sounds really good.
1. Bassani headers
3.Harley Torque cam
Did just RCX-haust Torx 4.5 mufflers only on my 114. Sounded ok, not impressed. Did RCX-haust Tormentor headpipe and RS468 cam with a PV canned tune from Fuel Moto. Now it has the rumble it should and the torque is much improved over stock. It will slide your *** back in the seat when you twist the happy grip. Zero issues with their tune.
