FLHX Cruise cable lash procedure not working, FIXED
So I installed the cruise on my FLHX. When you push the cruise switch the cruise icon on the tach comes on and the cruise switch light turns on. When I go to do the cable lash procedure per the service manual nothing happens. It says to push the resume switch, turn on the cruise and start the bike while holding the resume switch. It also says a green light should come on in the tach and go off. Once that happens push the resume again and hold to bring in the slack in the cable. The only thing is, no green light shows up in the tach and when I let the resume go and push it again no slack is taken up. BTW, the turn signals work.
HELP
Thanks
HELP
Thanks
RE: FLHX Cruise cable lash procedure not working
Make sure your front brake switch is working properly. I was having the same trouble and found out the front brake switch wasn't working properly and the cruise thought the brake was on. As soon as I fixed that everything worked just as it is supposed to.
How do you know if your front brake switch is working properly? It goes on when it is supposed in the garage. I have another question. I was reading the throttle cable adjustment for bikes with cruise and the talk about the idle cable having a switch on it for when you roll it forward. Do the FLHX bikes have that same idle cable even though they didn't come with cruise. It seems it's purpose is to disengage the cruise. You also need an ohmmeter to check the idle cable operation with the cruise. Any other FLHX owners had to do that?
Thanks
Thanks
I would dissassemble the right switch housing and look for a pinched wire--you may need to cut back some of the plastic sheath to get a good look, and check for a blown fuse.It's unlikely that you have a faulty cruise set/resume switch, and the fairing cap switch seems to be wired correctly since the switch light comes on and the tach light comes on.
Pinching a wire is very easy to do since the housings are such a tight fit with the audio and now cruise wiring inside.
ORIGINAL: swipter
Thanks
Thanks
ORIGINAL: swipter
Thanks
Thanks
Well the brake light doesn't stay on so I doubt that is the issue. I am going to take the housing apart one more time, cut back the plastic and look for a crimped wire. I will adjust the cables per the service manual except I don't have an ohmmeter. Guess I have to get one if I want to adjust them per the service manual with cruise section. It would be nice if it was a wire. When I push the resume for the lash procedure the green light comes on and goes off as the service manual says it should. Can it still be a pinched wire if that seems to be working? Now that I think if the set wire was pinched it would set. hope that is it. I can not tell if the lash is actually working. I do not hear any difference RPMs as the manual says the engine will do mark the cable at pressure. Thanks for all the help. If none of this works it is going to the dealer on Monday. I really didn't want to do that.
