Notices
Baffle wrap . to wrap or not to wrap ?
Old 09-01-2019, 10:06 AM
MyFavRk's Avatar
MyFavRk
MyFavRk is offline
Received 6,481 Likes on 3,902 Posts
Default Baffle wrap . to wrap or not to wrap ?
Last spring , I gutted a set of cvo muffler's and inserted a set of crusher maverick baffles . I tried them without using any baffle wrap and I ended up loving the sound .
After talking with some friends , I was told that by wrapping the baffle's , I would benefit my engine's performance by increasing back pressure , torque etc thus improving my tune . I do know that if I add wrap it would deepen the tone and decrease the volume . Not so sure about the other benefits .
My only question here is , Does wrapping the baffle actually do more than just change the sound of the exhaust note . Would there be more of a benefit to add baffle wrap to my exhaust .
I'm running a Arlen Ness stage 1 air cleaner , V&H True Duels and an FP3 . It runs like a dream and it has all the power I need to enjoy every mile I travel . I'm just asking out of curiosity .
Here are the baffle's I've installed for reference sake . Of course I had to modify them to fit .
I'm off to take advantage of a nice sunny day , but will be back later .... Enjoy the day !
Old 09-02-2019, 11:05 AM
cwsharp's Avatar
cwsharp
cwsharp is offline
One of my baffle wrappings blew out... (aftermarket mufflers). While I was deciding what different brand to buy I noticed that I got mild popping on decel and the pipe without the baffle yellowed.
MyFavRk (09-03-2019)
Old 09-02-2019, 12:28 PM
MyFavRk's Avatar
MyFavRk
MyFavRk is offline
I decided for the heck of it , I'm going to purchase some baffle wrap and install it , should only take about a 1/2 hr to get it done . I'm leaving on a short trip Wed so it'll give me a chance to see if there is any difference in performance . I expect the exhaust note to be deeper and a bit quieter , which should make anyone riding behind me a little happier .
I did notice a tiny bit a popping on decel , which never really bothered me at all , but if adding the baffle wrap helps get rid of it , that would only be a bonus .
Old 09-02-2019, 08:11 PM
Trucky911's Avatar
Trucky911
Trucky911 is offline
Hey MFR, I would like to know what kind of wrap and where you bought it. I need to re wrap my baffles. TIA...
Trucky911
Old 09-02-2019, 08:28 PM
MyFavRk's Avatar
MyFavRk
MyFavRk is offline
There's a local dealer here that specializes in dirt bikes , not sure what brand name they use but they sell it in pkg's . I usually buy 2 and that's enough to get the job done . I will be heading down there tomorrow morning to pick some up , so I can update on the type I use .
Old 09-02-2019, 08:47 PM
Bafflingbs's Avatar
Bafflingbs
Bafflingbs is offline
Shouldn’t be a difference in performance. A 2 &1/4” baffle, has the same opening, no matter wrapped or not. It’s really a misconception that you need back pressure. What you really need, is the escaping gasses, going as fast as they can. Too big, the velocity slows, too small and it’s like you put a cork in it. All the wrap does, is deaden the sound
Old 09-02-2019, 09:44 PM
harkon's Avatar
harkon
harkon is offline
FYI, dirt bikes run and perform better with the baffles wrapped.
Old 09-03-2019, 06:39 AM
caulk04's Avatar
caulk04
caulk04 is offline
I dunno about performance changes, but I'm awaiting some 'ceramic' matting to wrap my Rinehart cores. I've got $20 in two 1/2"x12x24 sheets. Already have some stainless zipties to attach it.
My hope is to just slightly deepen the tone and take a tiny bit of bark out of it.
Old 09-03-2019, 08:02 AM
MyFavRk's Avatar
MyFavRk
MyFavRk is offline
Your theory makes perfect sense to me , can't see any performance increase in adding wrap .
The dirt bike wrap I use is pretty tough , and is quite dense at 1/2" . I will post the type after I pick it up . Using stainless wires ties is an excellent idea , I've been using a roll of steel wire , the kind you would use for tying rebar for concrete work . I first tape it and then use wire to hold it in place after the tape burns off .
If anything , wrapping my baffles today should get rid of the slight popping I have , but I will end up sacrificing some volume . The baffle's I'm using are a Sound reduction baffle from Kuryakyn which keep the bike pretty tame and not so deafening while I ride , so I may end up going with a bit larger baffle in time to regain my volume .
Old 09-03-2019, 09:35 AM
Taggs's Avatar
Taggs
Taggs is offline
Trucky911
I recently wrapped my replacement Rhinehart high flow performance baffles with a ceramic high heat insulation found on eBay. It comes from seller in two sheets measuring 1X 12 X 24. Cost was $18.00. Actually only needed one sheet splitting it in half was plenty. The sound after was a much deeper tone. Didn’t notice much performance change.
PM me if you like. For the shipping I’ll send you the extra sheet I have left.
ultraglide12 (09-07-2019)
Quick Reply: Baffle wrap . to wrap or not to wrap ?
