2019 Road King Special - Turn Signals
Old 08-31-2019 | 09:49 AM
ksreed's Avatar
ksreed
Default 2019 Road King Special - Turn Signals
Guys-
Just took delivery of a new 2019 Road King Special.
As well, just received my new handlebars (pre-wired with new controls, plug-n-play).
I want to relocate the hideous, OEM handlebar-mounted turn signals to a set of flush mounts (similar to these https://www.revzilla.com/motorcycle/...yABEgLK4vD_BwE).
The pre-wired handlebars have the pigtail dropped out of the handlebar controls.
Does anyone have any thoughts/experience in the best approach for identifying the needed wires (for the indicators at the main plug (for the bars) and if there's anything to consider (given the pigtails for the turn signals have no less than 4-5 wires for each signal).
Just as an fyi, I have spent an hour or so scanning through previous posts for related information, but found nothing specific to needed wiring mods (since I'm not using a plug-n-play turn signal/headlamp assembly)
I've done many installs before. But these OEM signals on the bars are causing me a headache.
Thanks in advance.
Old 08-31-2019 | 10:03 AM
TracerBullet's Avatar
TracerBullet
Different strokes for different folks.
Can’t help you with your specific question. On of the selling points for me was the handlebar mounted turn signals
Old 08-31-2019 | 12:04 PM
6 gun's Avatar
6 gun
Originally Posted by TracerBullet
Different stroke for different folks. Can’t help you with your specific question. On of the seeking points for me was the handlebar mounted turn signals
Me to that is why I had mine moved up to the bars back in 08
Old 09-03-2019 | 07:11 AM
BensonUK's Avatar
BensonUK
if you are looking to get rid of the turn signals let me know, want to try and get hold of a set of US inserts so I can fit to my UK bike so I can fit 1157 bulbs
Old 09-03-2019 | 08:07 AM
6113_'s Avatar
6113_
it'll take a while to read through it, but I think the answer you're looking for is embedded in the Road King Special thread. I looked at it doing the same for a while, iirc it comes down to buying the Ultra Limited turn signal bracket, or using the standard Road King light kit and powdercoating.
I decided I liked the bullets on the handlebars and stuck with them
Old 09-06-2019 | 11:44 AM
ksreed's Avatar
ksreed
Was able to get the flush mount turn signals to work by tapping into the lead and ground for each in the headlight bezel. Unfortunately in ignoring the plugs near the grips, I'm getting error codes with one stating something about a short on the Run switch. Knowing all is good with the Run switch wiring, I'm thinking it has something to do with the un-used turn signal plug. The plugs have four wires: 1 continuous hot, 1 hot based on turn signal, and 2 (I believe both ground), No clue to how HD wired these things. Still researching...
Old 09-06-2019 | 12:01 PM
skratch's Avatar
skratch
if you go to the Harley sip site, you can download a copy of the wiring diagrams. that should help you out a bit.
https://serviceinfo.harley-davidson....60258081165344
Old 09-06-2019 | 12:30 PM
ksreed's Avatar
ksreed
Thank you Skratch! Yes, I'm sure this will help greatly!
nsnorgrass
06-19-2020 06:12 AM
Rogue8Man
Electrical/Lighting/Alarm
08-16-2015 03:45 PM
partlowr
02-02-2014 10:28 AM
SeniorChief56
10-09-2011 09:05 AM
dstegjas
09-21-2009 10:13 PM
Quick Reply: 2019 Road King Special - Turn Signals
