The question should be "what height bars are the most comfortable, and what do I need buy? "
If you'd be more comfortable with taller bars, it's silly to install shorter bars just because of the incremental expense of cables
12s are comfortable and don't look stupid 5" above the fairing. I'm not trying to make a statement, I'm looking for comfort. I've ridden bikes with 16, 18 and 1 with custom 20s. none are comfortable, and on the highway you're a 4X8 sheet of plywood facing the wind.
Your fortunate to be sure of the bar height you want. Now get the bars you want and lengthen anything that needs it for them to fit. My advice is if you have to re-rout or stretch things, they need replacement. Your on two wheels with no protection around you. Don’t take a chance on an equipment failure because of half assing something. Even a failed turn signal in heavy traffic could cost you everything.
