2008 Heat
2008 Heat
Just picked up a low mileage 2008 Electra Glide and need some advice. The heat from the exhaust is excessive to put it mildly.
1. Suggestions to help combat this.
2. Will any of the later style factory exhaust bolt, where the back pipe does not split and the crossover is under the frame? Seems like this might help.
I plan to install a set of heat deflectors to start.
Thanks in advance.
Thanks in advance.
I thought 2010 was the first year for a catalytic converter? I might be wrong lol it happens alot. If it's the stock exhaust you will benefit from a free flowing setup with a good tune ...that will help quite a bit. The deflectors...i took mine off and didn't feel any difference. I had those black plastic bolt on one's. There's a sponsor on here , captain itch that sells a deflector that gets good reviews.
Not sure where in Texas you are in but I don't think there is a part of the state that is not F'n hot right now. I'm in Houston. There's a lot of your heat issue right there.
If it still has a stock exhaust, find an after market exhaust system you like and get a good tune on it. A good two into one will move it all to the right. I have true duals on my 08 and am happy with them even if they aren't the best for performance. Exhaust and tune will cool it off noticeably.
2slow05 (08-18-2019)
EdwardK (08-18-2019)
Thanks in advance.
Thanks in advance.
