cutting windshield
cutting windshield
I am thinking about getting a recurved windshield for my streetglide but would like to go 1" shorter then stock. ( I am very short) I have read where a few people have trimmed along the lower edge on the batwing bikes. I have never considered trimming the lower edge but am considering doing this. Would like to see some pics of windshields that have been trimmed along the bottom edge.
You might check to see if their is a plexiglass shop near your location. I live near one and they have successfully trimmed existing windshields as well as manufacture new windshields. If not, if you have a small airport near you, ask if they have an a & p mechanic available. They are also trained in adjusting plexiglass.
I've trimmed many windshields over the years and only ever used a hand fret saw (not electric!). Some plastics will quickly heat up and stick to the saw blade, so slowly, slowly, catchy monkey, to avoid damage and embarrassment! I suggest simply applying a length of adhesive tape, parallel to the lowest edge, to provide you with a guide while sawing. A hand file will clean up the sawn edge, but do take care to avoid marking the visible shield surfaces.
GalvTexGuy (08-18-2019)
Ddieselsmoke (08-19-2019)
My stock 2006 windshield was about as tall as they ever were!
I've trimmed mine 3 separate times, just trying to find the height I wanted (I'm 5'8").
I trim the bottom and you also have to raise the cutouts for the 3 mounting holes where the screws clamp to the fairing. I'm now done cutting, the air goes just above my helmet. If it's raining and I want to get a good look at the idiot who's about to turn in front of me I just raise up an inch or two to look over.
To the guy who cut the top, if I did that it would look horrible! I hide my cut below the fairing, out of sight!
Cutting the bottom of a windshield is very doable (yes "doable" is a word). There are multiple tools you can use (hand saw, router, electric jig saw, etc.) Unfortunately most windshields taper quickly just above the point where the windshield exits the fairing. Every time you cut the bottom of the windshield reducing the total windshield height the width of the windshield as it exits the fairing will be reduced due to the taper. You will very quickly find you have a windshield that doesn't match the width of the top of the fairing. Looks, I believe the technical term is "funky."
I've experimented cutting a few windshields and enjoy that kind of work however if I didn't enjoy it and/or have the necessary tools I'd order a correct height shield from LRS or Clearview in a heartbeat. One man's opinion.
