Can I change cams myself?
RE: Can I change cams myself?
ORIGINAL: Scout
It's all about tools. If you have to buy or rent, it's cheaper to just pay a wrench a few bucks to do it.
Joe
Joe
http://groups.msn.com/HarleyTechTalk...30840018779458
Then, I used Harley Hogs site as a guide:
http://www.harleyhog.co.uk/camguidepage1.htm
BTW, I did not need or use a press. I used the oven/freeze method. You can see it here:
http://www.harleyhog.co.uk/tensionerinstall.htm
No special tools are really needed to get the job done, but a press helps out a lot.
I did a gear drive change in my bike in 4 hours, went from the 26G's to the HQ-0034G's.
Going from the stock cams to the gear drive cams is a bit more involved since you have to replace the inner cam bearings......but it is still very easy to do if you are mechanical and have the manual.
Steve
Steve
Yep, other than the factory exhaust if you still have it on your bike (huge P.I.T.A.), it's easy. Easier than doing a cam change in a V-8. I'm new to bike motors, but car engines I have done for almost 30 years. Bike is pretty much the same only smaller. But I'll say I wouldn't have wanted to do it with out the specialty tools needed going from chain tensioners to gear drive cams. I took my cam plate backto work on second shift when all the Suits and ties were gone and used the Hydraulic press in the Maint shop to press out the old stuff and press in the new. I had bought the inner and outer bearing remover/installer tool, plus the cam bearing tool. Yeah it cost me some bucks but I don't trusttoo many peopleworking on my stuff.
