Anyone here with a Muller hydro clutch?
I currently have AIM VP026-95IV on my stock 16 SGS. primary reason for me to install AIM was to reduce clutch pull. Although I like this feature of AIM there are 2 things I don’t like. First it only engages when you have throttle pulled in. Meaning I loose friction zone when I let go of throttle and it makes it difficult for me to maneuver my bike at slow speed in parking lots or other places. Like when I’m slowing down and let go of throttle, I cant feel the friction zone and loose control of bike. Second when throttling I can feel clutch engagement and it gets stiff to pull in or difficult when switching gears fast. I was told by AIM technician that the AIM clutch I have is meant for bikes that have stage 3 and up. I could get lower model of AIM clutch . But since it does not engage when I let go of throttle like a normal bike will do, I need to look at other options. I came across Muller hydro clutch.
On their description for 2016 models it says it Muller will reduce clutch pull effort by 30%, but for 2017 and up models they have different clutch that says it reduces clutch pull by 40%.
How much easier you guys think 30% will be ? Those of you who have Muller, what do you guys think of it ? Do you think I’ll be happy with it.
Thanks for for your feedback.
BTW I’ve also tried reckluse clutch . It has the same problem that it starts engaging only when you throttle up.
Thank you for the feedback. I'll definately look at it. Where is the engagement point and does it have enough friction zone (with AIM VPC friction zone is very less) ? I definitely want as much easy pull as possible. AIM VPC clutch I have starts engaging only when I throttle up, so I loose bike control when slowing down and throttle is dis-engaged. It's been 20k miles with this set up and I'm not enjoying slow manuvering my bike . I totally loose stability in slow speeds. AIM VPC I have to always pull my throttle for the bike to be in friction zone, Is it same with Muller ? or does it behave like a normal bike ?
I''l take it to the dealer for installation. how hard is the install, I dont want dealer quoting me 3 hrs lol
I have to ask...... could it be possible your VPC is not installed correctly or adjusted correctly.....???
This is the first complaint of this type I've read, or heard, about the AIM VPC... by design, it's not supposed to affect low rpm clutch pull or clamping. The clutch spring you use, should feel the same with or without the AIM VPC at low rpm, until the VPC starts to open up at higher rpm... then it just provides more clamping force than just the spring, and of course more lever effort...
Because the AIM slave was having leaking issues. I believe they are on a different revision now, but when I was doing this upgrade there was only Muller and AIM and AIM’s original unit was faulty back then.
Dan89FLSTC (07-12-2021)
People need to understand how both of these units really work. In order to reduce the force required on the lever, you are also reducing the travel of the clutch plates, THERE IS NO WAY TO STOP IT! Once you understand that one thing, the only way for them to be different in operation is if they are each reducing the travel and amount of reduce force is slightly different. So the one that has a greater reduction in lever force will have more reduction in the clutch travel and less friction zone, it's just that simple.
hattitude (07-13-2021)
