2013 FLHTK momentarily lost power, check engine light came on
Tonight while riding with a friend going about 45mph my bike hesitated (lost power) for 1/2 a second and then the checl engine light came on. The bike continued to ride normal. We got to were we were going and I pulled the codes, P0131, P1353, P1356, P1510, P2127, P3138. After pulling the codes the check engine light went off again and hasn't turned back on while riding. I looked at all the codes and it seems like a lot going on. I have read some stuff about bad connectors and using dielectric grease. Anyone have any ideas, or experience with this? Thanks
When a vehicle throws a code that clears, it could be: a one time glitch that will never appear again, a voltage drop, a symptom of something that is about to fail, or an intermittent problem.....
Of all those things, a voltage drop is the easiest & cheapest to check out. I would start with checking the battery, connectors (especially connectors of anything related to the codes), and grounds....
Good luck with the repair...
