2007, 2008, 2009 ultra
I am considering purchasing an older HD - Ultra. Model years 2007 - 2009. I want avoid spring chain tensioners as I am already dealing with that issue on two bikes. I also would like to avoid ABS and hydraulic clutch. Can anyone comment on:
1. Did 2007 - 2009 Ultras have ABS?
2. Did 2007 - 2009 Ultras have hydraulic clutch?
3. For 2007 - 2009 Ultras, any quality problems that have been widely seen across those years?
4. Any other comments for those years?
I ride bikes easy, so high performance is not what I am looking to buy. The bike would be for weekend trips in the 400 mile range. I want to avoid a design miss like spring chain tensioners.
Thanks for the help!
Uncle Larry (07-23-2019)
I'd go with the 2009 also. The ABS was an option on the 2009 Ultra Classic that I owned. I believe it was the second year of TBW (no throttle cables). The compensator was lousy and replaced with the SE version in 2011. It was the first year touring bike to use the Dunlop dual compound tires and ran the 180 tire on the rear instead of the 130 (2007) & 150 (2008) with the newer frame. No hydraulic clutch until 2014 Ultra Classic.
